"Attempt to access unallocated DensityLevel1 storage in cells Inlet"
Hi
I am running a unsteady implicit k-e Modell Model. Always if I am going to start my simulation this failure comes up: "Attempt to access unallocated DensityLevel1 storage in cells Inlet" I donīt get it, my simulation worked before (with a smaller mesh), I just increased the mesh resolution and thatīs it. Anynone can help? Thanks |
The error
I got the same error and I solved it as follow: In the " Representations" I removed all meshes except "Volume mesh". from " Volume mesh" I extracted the surface mesh. The problem was solved. I think the reason is that, volume mesh and surface mesh became the same. Good luck |
| All times are GMT -4. The time now is 01:58. |
