September 23, 2011, 02:42 |
Field Function shows an error
Niaz Ali Ahmed
Rep Power: 15 |
I am trying to write a vector field function to calculate 17/(Velocity^2)
I have tried 17/(pow($$Velocity,2)) 17/($$Velocity*$$Velocity) Both have failed. Is this because vector division is not possible, or some other error? However when I use a single dollar Velocity it shows assembly code. Please help me asap. |
September 23, 2011, 04:12 |
Jean-François Corbett
Rep Power: 14 |
There is no such thing as vector division.
I'm guessing you want to divide by the magnitude of the velocity vector? STAR-CCM+ provides two ways to calculate the magnitude of a vector: vector magnitude: mag($$u) vector magnitude squared: mag2($$u) So for you, the most straightforward expression is: 17/mag2($$Velocity) For more, see STAR-CCM+ help: Using Tools > Using Field Functions > Field Function Programming Reference > Vector Functions |
September 23, 2011, 08:17 |
Niaz Ali Ahmed
Rep Power: 15 |
@jfcorbett
Thank you very much. The problem is solved now. |
polynomial thermophysical properties II | sebastian | OpenFOAM Running, Solving & CFD | 54 | November 21, 2019 07:12 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
How to install CGNS under windows xp? | lzgwhy | Main CFD Forum | 1 | January 11, 2011 18:44 |
checking the system setup and Qt version | vivek070176 | OpenFOAM Installation | 22 | June 1, 2010 12:34 |
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." | sega | OpenFOAM Community Contributions | 12 | February 17, 2010 09:30 |
