torque calculation to find efficiency of fan
I have used mrf approach to simulate an axial fan and i want to find the efficiency of this fan. To do so I need 4 parameters (i.e del P, vol flow rate, rpm and torque). Can anyone tell, how I can find torque and which surface i should select to measure this torque value ? |
Create a moment report. The input surfaces for the report will be all blade surfaces which participate to the moment. Don't forget the rotating parts of the hub (when applicable).
i saw this in ccm and it is working. Thanks a lot friend !!
7 blades
Also ıf ı have seven blades how can ı calculate efficiency?
gozdamar, number of blades is not a parameter for determining fan efficiency.
blades
I took only one so that the effıcıency of one blade means all systems efficiency yes?
