-   STAR-CCM+ (http://www.cfd-online.com/Forums/star-ccm/)
-   -   Fatal error appeared in 3D-CAD modelling in STAR-CCM+ (http://www.cfd-online.com/Forums/star-ccm/93301-fatal-error-appeared-3d-cad-modelling-star-ccm.html)
fu030386 October 11, 2011 08:32
I created CAD geometry within STAR-CCM+. Problem is when I saved them and later wanted to edit the 3D-CAD geomerty part again. The server will automatically exit and present an error like follows:
java.net.SocketException:Connection reset
and in the Output window it delivers:
Server connection failed. This is usually due to a fatal error in the server.
This happened to almost every modell I built within STAR-CCM+. For other parts in the .sim file they all remain fine. But I just can not reedit the CAD part. Is this a bug of this software or anybody can tell me how to get rid of this error.
Thanks!
abdul099 October 11, 2011 17:22
Which version do you use? Windows or Linux? 32 or 64bit? Does this issue occur when opening the model on the same machine or a different? Can you make sure, this issure only occurs when doing something with the CAD modeller?
fu030386 October 12, 2011 05:17
The software version is 6.04.014. I use Win64 and the model is opened on the same machine. I've tried with different ways of saving the file. Now I would be sure it must be the error within the CAD modelling.
I rebuilt the CADmodel again and it works fine. But if I made some modifications to the model, the error appeared once again. I would say that the software may be very sensitive with modifications, which can be improved in the futur development.
abdul099 October 20, 2011 22:42
I'm sorry, I wasn't able to reproduce a similar error. I'm using v6.04.016 and never had an error with modifying an existing model. Further more I'm using the CAD modeler since v5.02 and never got a problem similar to your description.
Could you give a detailed description what steps you did? Does this problem also occurs on a simple model or does it need to be a complicated, confidential geometry for this problem to occur?
