Porous Medium Question
Old   April 17, 2012, 01:48
Default Porous Medium Question
Hamza Motiwala
hamzamotiwala is on a distinguished road
Hey Friends,
I defined a part of my geometry as a seperate porous region. The output velocity from the porous region is approximately 20m/s lesser than what its suppose to be.
I tried changing the porosity, the dissipation rate, the material properties, the resistances..i just cant seem to get the right combination or hit the right option.
The porous medium also acts as a heat sink. I use the material properties of aluminium.
Does anyone have any idea with what settings can I increase the output velocity from the porous medium?
Thanks,
Hamza
hamzamotiwala is offline   Reply With Quote
Old   April 20, 2012, 02:55
Ping
ping is on a distinguished road
first turn off porous media and ensure you achieve a reasonalbe flow - if this does not happen then addiing resistance is not going to improve it!
then with porous on start with very low values for viscous and inertial coefs eg .001 - might be unstable, and slowly increase them until to get near you required flow rate.
ping is offline   Reply With Quote
Flow through porous medium Kiran AS FLUENT 6 September 16, 2011 07:38
Heat Transfer in Porous Medium eryan STAR-CD 0 September 28, 2010 13:14
Modelling sound propagation through layered porous media nkinar Main CFD Forum 0 July 4, 2010 14:45
Have one question, almost porous medium. lobzik FLUENT 2 June 21, 2009 21:33
porous medium as heat source Ralf Schmidt FLUENT 1 November 4, 2005 13:12
