Home > Forums > STAR-CCM+
Porous Medium
Old   February 27, 2012, 05:14
Default Porous Medium
sam
Sam0508 is on a distinguished road
This is sam from coimbatore,India.I've read the below content.I have a doubt in this, how could i calculate the Dp/L by using CFD sofware.
Let i take pipe Dia 250mm length 2m. The porous region is located at 1m(middle section) porous thickness 0.25m.In this i have to consider either Total pipe length 2m or Porous lg 0.25m for find initial Parameter of Dp/L with diff velocity V m/sec for get the excel plot(K and C2). Anyone can help me
Regard,
Sam
The formula is
Dp/L= [(viscosity/alpha)*velocity]+ [C2*1/2*density*velocity^2]
(dp/l =viscousr resistance + inertial resistance)
plot dp/l vs velocity in excel. The pressure drop can be obtained from cfd.
The values for velocity can be arbitrarily chosen say for ex. 0 to 20 m/s (even more if you want more points)
Plot Dp/L vs velocity based on above formula and examine the curve how it looks like. If it is a straight line then use only dp/l=viscous resistance.
If it is a quadratic equation use (dp/l =viscousr resistance + inertial resistance). Find K and C2 with these curves.
Hope this helps .
cheers
Nelly
Sam0508 is offline   Reply With Quote
Old   March 7, 2012, 19:07
abdul099 is on a distinguished road
You only have to consider the porous part of your domain, since the straight pipe before and after the porous part is not covered by the Dp/L formula.
It depends on your type of problem whether you can take Dp/l from a CFD simulation or not. Please describe your problem a little more accurately. What parameters do you have? What do you want to know? How does your porous part look like?
abdul099 is offline   Reply With Quote
Old   March 9, 2012, 05:36
sam
Hi Abdul099,
Actually i want to simulate the Pr.drop by CCM+ software itself.
u r saying i've consider where the porous region is present for find Dp value am i right(need not consider the total pipe length)?
u consider above pipe dimension,at middle the cotton matl is present...what will be pr drop effect by cotton matl? and how to do this in CCM+? give me ur idea ..... Adv Thanx
Regards,
Sam0508
Thread Tools
Trackbacks are On
Flow through porous medium using CFX: lack of convergence Chander CFX 3 July 23, 2014 06:32
Lack of local thermal equilibrium in porous medium Chander CFX 4 March 4, 2012 05:07
How to use non-equilibrium thermal model for porous medium in Ansys CFX 13.0? Chander CFX 3 November 28, 2011 15:26
Modelling sound propagation through layered porous media nkinar Main CFD Forum 0 July 4, 2010 14:45
porous medium and reactions Valeria FLUENT 1 July 10, 2009 03:58
