February 28, 2012, 09:15 |
Cylinder Mesh and Physics models!
James
Rep Power: 14 |
Hello!
I am undertaking a small side-module at my college involving Star CCM+. Our task for this is to create a cylinder with vortex shedding off of it, we are meant to use a quite low reynolds number (I have chosen 200). My questions are: What would be the best meshing models for the cylinder? And what sizes would you advise for the best mix of good results, but not huuge simulation time? What physics models should I use? I assume that because the Re number is low, the model should be Laminar, constant density, segregated flow etc? Many thanks to you all! Oh, and its a 2D model at the moment, maybe 3D later, are there any things I should change when transitioning between the two? Thanks |
February 28, 2012, 09:18 |
James
Rep Power: 14 |
oh and sorry for such a basic question
We all have to start somewhere! |
February 28, 2012, 23:35 |
aerosapien
Rep Power: 15 |
try this >>>>> http://www.docstoc.com/docs/23537770...er-in-Star-CCM
regards www.aerosapien.blogspot.com |
February 29, 2012, 06:35 |
#4 | |
James
Rep Power: 14 |
My other question is, they are using a turbulent model, whereas I think mine should be modelled as laminar? (Because the Re is 200). BUT, a friend of mine just suggested we use a transient model, like k-epsilon with turbulence suppression before the cylinder, to model vortex shedding from the cylinder? Do you back up his idea, or is he wrong? I am achieving shedding with laminar, but I am now concerned whether it should be modelled with turbulence! Many thanks Also, your blog is very interesting, aerospace is an area I am certainly looking to do a degree related to! |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 03:19 |
1 Was FSI for a flow over a cylinder | vmlxb6 | CFX | 17 | May 16, 2011 02:29 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
Iterative equation solvers in CFD | Vitaly Bulgakov | Main CFD Forum | 32 | March 1, 1999 11:11 |
