calculation stops and BICGStab did not converge |
March 5, 2012, 20:38 |
Xiao Liu
When I try to run the calculation, it failed and the output is as below, who has met this problem and solved it?
BiCGStab did not converge ! * CFL 5.00000e+00 -> 5.00000e-01... BiCGStab did not converge ! A floating point exception has occurred: floating point exception [Invalid operation]. The specific cause cannot be identified. Please refer to the troubleshooting section of the User's Guide. Command: RunSimulation CompletedCommand: RunSimulation In: [Machine::main, SimulationIterator::startSimulation, SteadySolver::step] error: Server Error |
March 6, 2012, 03:19 |
siamak rahimi ardkapan
Rep Power: 17 |
I had this problem, and it was because of the mesh quality. check the cell quality by Threshold. Find the worst cells. choose the Cell quality remediation model in the Physics models. Also you can right click on your regions and remove the low quality cell if they are few.
good luck |
bicgstab, floating point exception |
