Diverging Eulerian Multiphase
1 Attachment(s)
I am simulating particles in the air.
The geometry is a room and a candle inside. When I try steady state, it shows from the beginning floating point. When I use Unsteady with low relaxation factors, it works to some extent, but whenever I change it to steady state, again it starts to diverge. Any advice is highly appreciated. Thanks |
Looks like an Eulerian multiphase simulation, right?
In that case, run it laminar, it's very unstable when running it turbulent. Another try is to reduce under-relaxation factors to very very very low numbers. Or even better: Try both at the same time! I understand that's not satisfying, but unfortunately the Eulerian approach is very unstable under turbulent conditions. There are too much equations affecting each other. |
Thanks abdul099, it is so nice of you :)
Did you get the solution with steady state? I have the same problem. can you help me! thanks in advance best! Kanarya |
