-   STAR-CCM+ (http://www.cfd-online.com/Forums/star-ccm/)
-   -   Source Term (http://www.cfd-online.com/Forums/star-ccm/98484-source-term.html)
itsme_kit March 12, 2012 10:22
Source Term
Once I got the graph where flow rate against pressure
How can I get this result as a source term in to Star-ccm?
Thanks
itsme_kit March 12, 2012 10:23
The resullt is taken from modelling a diaphragm pump
ryancoe March 14, 2012 09:46
There's a fan model you can be use with a momentum source region that I think should do the trick.
itsme_kit March 14, 2012 17:34
Actually it is a diaphgram pump
ryancoe March 15, 2012 09:08
Unless you want to model the temporal phenomena of the pump (in which case you'll need to know more than flow rate vs. pressure), you can still input your curve into the fan model, right?
