How to model Eulerian multiphase and Species Conservation at the same time? |
March 13, 2012, 11:49 |
Can Huang
Hallo ,everyone
I am going to model a solidification process. I use the Multiphase segregated flow model to model the solidified phase and melt phase. These phases are all of multi-components. Problem is : When the Multiphase segregated flow model is selected, the Multi-Component Liquid models can not be selected. That's to say, in starccm+, How can I solve the species conservation equations while the mass conversation equations with volume fractions are solved? Thank you very much if any one have those experience |
March 13, 2012, 12:38 |
siamak rahimi ardkapan
Can you explain more?
After you selected the Multiphase model you can determine the material you need. Check the tutorial for the Eulerian. |
March 14, 2012, 06:22 |
Can Huang
Thank you very much for your reply
problem description: two phase flow with two components I want to model a solidification problem, the material is a melt. Its two components are iron and carbon. Carbon can diffuse and convect in the melt. I use Multiphase segregated flow to model the phase change(from liquid to solid), in each phase, at the same time I want to know the carbon distribution in the melt, so I have to solve the species conservation equations for each Euler phase(melt and solid). In the Material selection, Multi-Component Gas and Multi-Component Liquid models can solve the species equation, but in a single phase. Beside them, Multiphase Mixture can be choosen. So I choose Multiphase Mixture. Then under the Multiphase Flow Model there are two models, one is Multiphase Segregated flow, another is Volume of fluid (VOF). This is the problem! I want to solve the species equations with Multiphase segregated flow model. But if I use Multi-Component Liquid model I can't not choose Multiphase Mixture at the same time. |
March 14, 2012, 08:28 |
In the icon, Multiphase Interaction you need to define the two interchages ( carbon-melt and carbon-solide).
eulerian multiphase model, multi component, solidification, starccm+ |
Eulerian multiphase model for species trnasport: UDF for reaction rate | harsh | Main CFD Forum | 3 | June 12, 2017 02:24 |
Species Transport with Multiphase flow in FBR | venkat | FLUENT | 1 | July 23, 2008 23:53 |
Eulerian Multifase model with species transport | Valeria | FLUENT | 0 | July 19, 2008 16:48 |
Multiphase model and species transport | Reginaldo Cotto | FLUENT | 0 | August 29, 2006 20:36 |
Species Transport with multiphase flow | Gopal Kasat | FLUENT | 3 | July 12, 2005 18:59 |
