Prism layer needed to resolve laminar boundary (lowRe)
Old   April 7, 2012, 07:15
Default Prism layer needed to resolve laminar boundary (lowRe)
M10
Mio S
M10 is on a distinguished road
Hello.
I'm trying to simulate an airfoil with Reynolds range 10**4 - 10**5.
For now, I'm using k-e to initially obtain a converged solution, and then switching to k-wSST for a better separation. Yaw range is 0-20deg.
If anyone has an experience in this type of analysis, I'd love to know the layer thickness and #s of prism layers one should be using to capture the laminar boundary layer/laminar bubble/turbulent re-attachment (I believe this will be hard). If there's any other tips and tricks for low Re modeling would be appreciated.
Thanks.
M10 is offline   Reply With Quote
Old   April 11, 2012, 07:02
siara817's Avatar
siamak rahimi ardkapan
siara817 is on a distinguished road
Hi
I think to simulate properly the low Reynolds ranges, you need to generate a fine surface mesh, otherwise it will be hard to converge.
Good luck
siara817 is offline   Reply With Quote
Old   April 11, 2012, 14:30
Ryan Coe
ryancoe is on a distinguished road
You'll want to have a prism layer to give a y+ < 1. You can use the tool linked below to give you an idea of the grid spacing needed to achieve this.
http://www.pointwise.com/yplus/
Ryan
ryancoe is offline   Reply With Quote
Old   June 11, 2012, 09:44
Ruben Ruiz
RGRUIZ is on a distinguished road
you should have at least 10 layer inside the viscous sublayer...best luck
RGRUIZ is offline   Reply With Quote
Old   June 15, 2012, 16:21
abdul099 is on a distinguished road
For low angles of attack, I usually try to estimate the thickness of the boundary layer by calculating the boundary layer thickness of a flat plate. This gives at least an idea how thick your prism layers should be in total.
This doesn't work for high angles of attack when flow separation occurs. But in this case, you will most likely get crap from most turbulence models, so I think it doesn't matter anymore how thick your prism layers are in the separation zone.
We do three types of jobs here:
GOOD, FAST AND CHEAP
You may choose any two!
abdul099 is offline   Reply With Quote
airfoil, k-omega sst, low re, transition model
[snappyHexMesh] Boundary layer in a pipe Clementhuon OpenFOAM Meshing & Mesh Conversion 6 March 12, 2012 12:41
Trimmer & prism layer peresah STAR-CCM+ 6 October 6, 2009 14:39
Help needed with laminar couette flow boundary conditions bengt OpenFOAM Running, Solving & CFD 0 March 19, 2009 08:25
urgent: 2d laminar boundary layer simulation Abhishek Main CFD Forum 2 August 1, 2006 19:17
