Reversed Flow Error(pressure correction limited...)
1 Attachment(s)
I have a body surrounded by a block(Air).
I considered LeftWall of the block as 'velocity inlet' and Right one as 'pressure outlet' to have a flow with a constant temperature over my heated body to consider the influence of the air on my body. Also i used the default value of the inlet and outlet walls. Using both Coupled and Segregated Solver give me the warning about pressure correction limited on many faces and reversed flow. I appreciate if anyone has any idea or suggestion. |
Hi
If you use buoyancy with Boussinesq model ,then double check for the reference temperature (which is most be near the domain temperature ). |
I did not use the boussineq model. But i ignored the 'gravity' and now it works better.(I get the reversed flow error after the first iterations just for 6 or 7 faces now) Do you know the influence of gravity in my case? can it be ignored? Many thanks in advance. |
Hi
If you have an air in touch with hot surface than you have a change in the density, and this will generate a buoyancy. If you ignored the gravity it will solve the issue of reversed flow, but it will not be a realistic flow. |
It probably means you need to refine the mesh. If you are seeing reverse flow then it could mean your outlet is too close. If possible extend it. |
| All times are GMT -4. The time now is 08:43. |
