Fuel film on piston and cylinder
Hello
how to get the fuel film on the piston and cylinder in fuel-air mixing analysis in star cd. this is how cell data stored { CELL DATA SU "Velocity Component U" m/s SV "Velocity Component V" m/s SW "Velocity Component W" m/s MassFlux "Mass Flux" kg/s P "Pressure" Pa PTER "Thermo. Pressure" Pa TE "Turb Kinetic Energy" m2/s2 ED "Dissipation Rate" m2/s3 VIS "Turbulent Viscosity" Pa s T "Temperature" K H "Enthalpy" J/kg DENS "Density" kg/m3 CP_M "Mean Specific Heat" J/kgK CP "Specific Heat" J/kgK COND "Conductivity" W/mK CONC_001 "C8H18" CONC_002 "N2" CONC_003 "O2" CONC_004 "WFMASS" CONC_005 "WFTHICK" CONC_006 "WFTEMP" CONC_007 "RG" VOID "Void Fraction" } Thanks in advance. Regards, Krishna |
1 Attachment(s)
wall date has saved as attached:
Assuming you activated the liquid film model & did all the appropriate setup steps. The liquid film information will be stored in the wall data. To get film thickness use the command: getw lfthk.
Thank you so much for your reply.
i have tried that command getw lfthk, it is giving this below error: CREATING WALL BOUNDARY SHELLS **INTERNAL ERROR - FAILED TO CREATE SHELLS FROM CELL FACE,ITER= 1 ICNEW,ICA,IFACE,ICTDUM=638898 535803 16 139 **ERROR - CREATING BOUNDARY SHELLS i am following this procedure 1. loading the post date 2. events running 3. storing the time 4. getw lfthk can you please suggest me. Thanks in advance. |
That sounds like a bug. You should contact cd-adapco support.
