biodiesel operated diesel engine simulation-is it possible? |
August 14, 2011, 01:28 |
jaichandar
Hi everybody!
I want to simulate a diesel engine using biodiesel as fuel.Is it possible to carryout the combustion analysis with the available combustion model in star-cd.One of my friend who knows CFD says combustion anlaysis of biodiesel fuel cannot be carried out using star-cd.Is it correct.If correct how can i simulate.I am eagerly expecting for your replies. Thanking you With Regards |
August 16, 2011, 10:17 |
Pauli
Rep Power: 17 |
What reason(s) did your friend cite?
Off the top of my head, I can not think of a reason why the StarCD models are not as suited to biodiesel as they are to "regular" diesel. You will have to update all the appropriate fuel properties. |
August 16, 2011, 13:24 |
jaichandar
He says that STAR-CD combustion model was developed for hydrocarbons(like diesel or petrol) and not for oxygenated fuels like biodiesel. since the combustion (chemical) reactions of biodiesel are different from diesel we cannot use any combustion model of STAR-CD.
May 9, 2012, 08:32 |
zhangbo
i want to know whether you still simulate biddiesel combustion?
July 18, 2012, 07:09 |
Blanco
Rep Power: 17 |
I think that you CAN simulate biodiesel combustion in star-cd, probably you can't use a "ready-to-use" setup but you can do a new setup for this kind of simulation.
For example you can define what kind of reactions takes place in your combustion chamber, in order to take into account the oxygen "generated" from the fuel |
Need some help regarding diesel egne simulation | deepon | Main CFD Forum | 1 | March 29, 2016 04:58 |
engine simulation | uday | Main CFD Forum | 0 | December 22, 2009 01:24 |
IC Engine Flow simulation | Apurv | Main CFD Forum | 2 | February 8, 2000 00:12 |
Engine simulation (seeking help with method to use) | Geoff Rathbun | Main CFD Forum | 4 | April 13, 1999 14:19 |
Question concerning about the flow simulation of a fan in an engine room. | ghlee | Main CFD Forum | 3 | October 21, 1998 07:05 |
