May 12, 2012, 05:19 |
negvol error in starcd
hi all,
i am getting error of neg volume in create results. when i gave th run iterations stopped at 12 saying negative densities found. can anyone tell me the solution to fix the error. |
July 18, 2012, 07:07 |
Blanco
Rep Power: 17 |
is this a moving mesh or a static mesh?
The run stops because probably you have a very bad mesh... |
July 18, 2012, 21:08 |
U can repair in static mesh
Krishna
Rep Power: 14 |
you can do these steps after finishing create results 1. read result 2. type check negvol 10 ice <here 10 is just randam cset, u can use different also> 3. cset news cset 10 4. cplo 5. check these cells, where it is, if it is in static region correct them by using filling linear or some other else. I think u know most of these, but for info i am written here. Please inform the present status |
Display Modes | |
Conj. Heat Transfer: STARCD vs. STARCCM+ | Stefano | Siemens | 0 | September 24, 2007 08:55 |
StarCD display problem | cfddummy | Siemens | 3 | April 9, 2007 16:59 |
StarCD and HyperMesh | Joseph | Siemens | 3 | March 28, 2007 13:56 |
how to read a gridpro 2d file into starcd shell | prc | Siemens | 3 | December 21, 2006 18:59 |
Convert from StarCD 3.10 to StarCD 3.15 | Jing | Siemens | 1 | April 17, 2002 09:22 |
