Home > Forums > Software User Forums > Siemens > STAR-CD
stagnation pressure boundary problem
Old   January 27, 2010, 08:15
Default stagnation pressure boundary problem
mbgnfrx2 is on a distinguished road
Hi everyone,
I am simulating a simple case with a inlet and a outlet, using stagnation pressure boundary condition for inlet and pressure boundary for outlet. However, I cannot figure out why star-cd always tell me "Error 012: Static pressure greater than stagnation pressure at region 1 negative. Try to lower relaxation factor for pressure and/or velocities." The stagnation pressure is set as 1000 at the inlet, with outlet pressure 0. There is no other way to setup the boundaries any more, as we only know the inlet and outlet pressure.
Many thanks in advance!
mbgnfrx2 is offline   Reply With Quote
Old   November 23, 2012, 19:48
immortality's Avatar
Ehsan
immortality is on a distinguished road
hello
I have this problem now.How did you solve this problem finally?
immortality is offline   Reply With Quote
Old   November 25, 2012, 23:55
Lucky
Originally Posted by immortality View Post
hello
Check your calculations to make sure you have the appropriate Inlet Total Pressure.
You need to know indirectly, static pressure (also called supersonic static pressure), total pressure, mach number, static temperature, and total temperature (3 of these 5).
How to give pressure boundary condition in SIMPLER algorithm shyamprasad Main CFD Forum 0 March 16, 2009 23:40
stagnation pressure boundary condition xqy Phoenics 6 July 1, 2004 03:43
how to set the stagnation pressure boundary xqy Phoenics 4 November 28, 2002 20:04
Role of Boundary Pressure Jim Park Main CFD Forum 2 May 29, 2000 01:13
Pressure boundary condition Brindaban Ghosh Main CFD Forum 6 May 3, 2000 13:11
