Problems with es-ice in linux and modelling of the valve profile
I'm new with star-cd and es-ice. My first problem is, that I can not start es-ice in linux (OpenSuse 12.2, 64 Bit). Here is the text from the bash: "error while loading shared libraries: libXm.so.3: cannot open shared object file: No such file or directory" I already checked if openmotif is installed and thats ok. Thats the reason why I run es-ice in Windows XP (32 Bit) and so I come to the secound problem. I try to run the tutorial for es-ice and stop in chapter 3 at the Point "Modelling the Valves" with the error: "mesh2010 failed to run correctly" This error occurs after clicking the "create profile"-button in the "Create valve profile"-template. I hope that somebody can help me :confused:. Best regards Marco |
I guess your star cd version is 4.18.
you can try "Defining a Valve Manually" as seen in chapter 5 of es-ice user guide, which is the conventional method in older version eg. star cd v 4.16. Quote:
I have the same problem : I try automatically and manually and the message is the same:
"mesh2010 failed to run correctly" I cannot continued with the tutorial by this problem. I do not know what is wrong? Someone can help me? |
Hello Skylent and gamadordiaz,
first thanks for your reply to my thread. Unfortunatly I could not try the manual valve definition until now because I was in trouble with other things. On the other hand I have the chance to run CONVERGE and this is much more comfortable to handle than Star CD. If I work with Es-ICE again and find a solution I will post it here. |
about your problem dealing with the libXm.so.3. I've installed the libmoti3 with: Code:
sudo apt-get install libmotif3 |
Hello Users,
now I'm back in the project. I solved the problem with the installation of es-ice in opensuse 12.2. If I type in a shell "user@host;linux64_2.6-x86-glibc_2.3.4-gcc_4.4.3-ifort_11.0/bin: ldd es-ice", then I get the message that the path for libXm.so.3 was not found. If I type in "ls -l" in the files were the libXm.xo.3 exists (/usr/X11R6/lib64/ and /usr/lib64) I get the info that it links to the 32-bit libaries (/usr/lib/libXm.so.3). To solve the problem I installed the package "openmotif22-libs-2.2.4-192.1.3.x86_64.rpm" what you can find here: http://rpmfind.net/linux/rpm2html/search.php?query=libXm.so.3%28%29%2864bit%29 Now the system is running and I hope that I can solve the second problem with the help of skylent. Best regards Marco |
Now I can run es-ice with opensuse 64-bit and the valve modeling works well. So the second problem is solved to.
Thanks for your help and best regards. Marco |
