Circulating outlet boundary solution to the inlet |
May 19, 2014, 07:17 |
Rep Power: 13 |
do you know how to circulate an outlet boundary solution to the inlet in a pipe flow case ? My case is compressible (mainly temperature induced density changes). It would be sufficient to circulate the outlet solution to the inlet only a few times. So a constant circulation of the solution is not required (as in compressible solution this leads to difficulties). Thank you. |
Display Modes | |
Outflow boundary condition in cartesian grid SIMPLE velocity-pressure coupling | ghobold | Main CFD Forum | 9 | September 19, 2015 03:50 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 07:28 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 05:05 |
inlet and outlet boundary condition for turbomachinery solution | siamak1424 | OpenFOAM | 2 | August 15, 2009 12:14 |
New topic on same subject - Flow around race car | Tudor Miron | CFX | 15 | April 2, 2004 07:18 |
