October 1, 2009, 03:11 |
Problem with restart
Rep Power: 16 |
Good morning everybody,
I am running a simulation of an ICE with star v3.26 and an Es-Ice 2.10 model. During the es-ice model preparation, I have set as end of the simulation 720°CA, and now I have completed successfully the simulation. However, now I would like to restart the simulation, from 700°CA using one of the .pst file I have created during the simulation, and finish the simulation later than 720°CA, let say 800°CA for example. What I have to do to use exactly the same model? The only thing I would like to change is the end of the simulation, however changing it in es-ice "Star setup" panel, than I have also to set the star control panel and create the model again, and since some boundaries change numeration, I can not more use the .pst file I have. I hope I have explained enough clearly my problem, anyway please ask me if you need more details, thank you in advance for your kindly support, Enrico |
October 23, 2009, 08:07 |
Rep Power: 17 |
I guess you might have already solved your problem.
In my experience, to re-set-up doesnt change any boundary number or cell type. I think you can just set up and use the event file newly generated. I am not quite sure, but i think its worth a try. Mepgzzi |
October 25, 2009, 07:29 |
Manish Garg
henryss, you need the new event file. To avoid any problem, follow these steps:
>> take the save_ice and save_es-ice file in a separate folder >> do the star setup with new crank angle >> take only new MAKE_EV.BAT and save_ice to the old folder >> resume old model in Prostar, Hit the event button in the es-ice.PNL Make sure that maxeve is set to new maximum events, and do memo write. Now it should work. Manish |
Display Modes | |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Incoherent problem table in hollow-fiber spinning | Gianni | FLUENT | 0 | April 5, 2008 10:33 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
Backup & Restart problem | Sally | CFX | 4 | November 19, 2005 12:44 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 14:52 |
