February 1, 2010, 09:17 |
Heat flux
Denis
Rep Power: 16 |
Hello!
Please, help me! How to set heat flux in Star-CD? Please write if you have any ideas. |
February 1, 2010, 10:57 |
Pauli
Rep Power: 17 |
rdef,2,wall,standard
noslip,rough,0.001,0,8.5,0,1 0,0,0,1,0 flux,0 |
February 2, 2010, 01:50 |
Denis
Rep Power: 16 |
Thanks Pauli!
Now I need to set heat flux in [W/m3] or loads in [W]. Please write if you have any ideas. |
February 2, 2010, 11:08 |
Pauli
Rep Power: 17 |
RTM
3. Flux — (constant) wall heat flux value [W/m2] |
February 3, 2010, 08:31 |
Denis
Rep Power: 16 |
There is a 3D model in which through a solid heat flux is passed. A body unevenly cools down a liquid, that condition uneven heat flux from all surfaces. I must count up distributing of temperatures in models and wall heat flux coefficient. For this purpose it is necessary to set a by volume heat flux for a solid [Вт/м3].
Help please, what method it is possible by to set him? Found only how to set a superficial thermal stream [Вт/м2], but for set the problem he will not give a necessary result. Please write if you have any ideas. If something is needed to specify, ask, I will tell. |
February 3, 2010, 11:36 |
Pauli
Rep Power: 17 |
Sounds like you want to specify a volume source. If so, you can use the command rsource or the user subroutine sorent.
Total heat transf. rate vs Total surface heat flux | Renato Sousa | FLUENT | 1 | April 14, 2020 03:27 |
Sign of Heat Flux at wall | Kyung | FLUENT | 2 | February 26, 2016 16:25 |
Heat Flux Wall Boundary Confusion. | Joee | FLUENT | 1 | August 21, 2010 12:20 |
Heterogeneous heat flux | Kev | STAR-CD | 4 | July 7, 2009 04:48 |
Heat Transfer Coeff. at Heat Flux Boundary | Rushyen | CFX | 6 | January 18, 2001 05:09 |
