using K-W models for wind simulation around tall building |
March 13, 2010, 07:15 |
How to use K-W models for wind simulation around tall building??/
Salman Najm
Hi everyone,
I am carrying out wind flow simulation around tall building as part of my dissertation. I have used K-E (k-epsilon) model it looks o.k. but when i tried to use K-W model the pressure counter goes funny. I did not put any values for the Box Omega(rpm)_____ in the "Define the boundary conditions tab" and left the default value o. What values could i use as a rough guide, or leaving it as a default value should be o.k. For the K-E i used k=0.025 and E=0.07 as defined in a similar simulation as mine, in the star-cd userguide. Pne last thing, how do I find the errors of each simulation? i mean how do I compare the k-E and K-W model simulation for the same conditions and show that one is more accurate then the other. If someone can guide me in the right direction that will be much appreciated........ Tanx in Advance.......... Last edited by waisprince; March 13, 2010 at 07:45. Reason: To make it sound like a question |
W are the job opportunities in Building simulation | suavi | Main CFD Forum | 3 | October 4, 2007 13:49 |
Building Simulation | Apostolos | Main CFD Forum | 1 | October 14, 2005 08:02 |
Fire simulation using FDS from NIST | Jens | Main CFD Forum | 1 | January 22, 2004 01:53 |
Large Eddy simulation | Andreas Hauser | Main CFD Forum | 1 | May 20, 2000 20:33 |
3-D Contaminant Dispersal Simulation | Apple L S Chan | Main CFD Forum | 1 | December 23, 1998 10:06 |
