-   STAR-CD (http://www.cfd-online.com/Forums/star-cd/)
-   -   monitoring boundary and engineering data (http://www.cfd-online.com/Forums/star-cd/74542-monitoring-boundary-engineering-data.html)
Lawrence April 2, 2010 20:25
Dear all,
I am using STAR-CD 4.12. I am working on transient simulation with some monitoring boundaries. Then after the case has been run successfully, I get the engineering data file *.erd.
But there are too many data points in this file. I think the data at every iteration have been recorded rather than every time step.
Could you please let me know how I can set the recording interval for the engineering data? It seems that it is recorded every iteration by default.
Thank you!
Lawrence
Pauli April 3, 2010 09:42
The erd file records every time step. You can not change it.
Lawrence April 3, 2010 11:16
Thanks Pauli !
I would like to convert this data file into some other format like txt or excel. Is it possible? Because I usually use Matlab to process the data.
Lawrence
Pauli April 5, 2010 10:50
Use edgraph & edload to load the erd/ecd information into the graph registers. Then use sdata to write the graph registers to a text file.
Lawrence April 6, 2010 14:58
Yes, you are right!
I have got the text files using your method.
Thanks.
