-   STAR-CD (http://www.cfd-online.com/Forums/star-cd/)
-   -   Auto Mesh Tool usage (http://www.cfd-online.com/Forums/star-cd/78555-auto-mesh-tool-usage.html)
mbilalm July 26, 2010 02:52
hello
i could not use the automesh tool as mentioned in the meshing tutorials
after the import of grid when i "run checks" star CD abruptly stops and can not proceed
the problem is with the self intersecting surface (maybe)
please guide me how can i help myself
enriko_85 July 28, 2010 04:51
how do you build your grid?
e
mbilalm July 28, 2010 07:44
i followed the meshing tutorials
in tutorial 2 the grid is available in the installed files
the steps i performed were identical
enriko_85 July 28, 2010 08:11
mh...I see...try to go back to pro-surf and run a check. You should get an error message if surfaces are self intersecting. You could have to delete and recreate/retrim some of them.
e
mbilalm July 28, 2010 20:29
there is never an error message
i have tried to eliminate surfaces and tried to merge surface or curves but nothing has gone right in this case
to me tutorial 3 also has the same problem
can there be something wrong with the version i have installed
4.06
4.08
both have the same problem
also i am trying to link user coding with star CD but i am unable to do so
i have installed MS Visual Studio 2005, then Intel Fortran compiler 11 and then SDK for windows server 2008
the messege is always lib.exe can not find and C fortran file does not contain lib.exe
are these problems inter-connected
please guide me
thanks
mbilalm July 28, 2010 20:31
i want to add to the previous statement that there is never an error message when i check self intersecting surface
the program stops abruptly and system is halted and i need to use Task manager to end the program
TomK July 30, 2010 18:58
Are you using Microsoft for your OS? I was never able to get version 4.08 to run in Windows (did not try 4.06) and CD-adapco tech support could not help me. Finally used virtual box and installed LINUX and it ran ok.
For FORTRAN compilers I think it is required to use the ABSOFT compiler up until version 4.12, then you must use INTEL.
TomK
mbilalm July 30, 2010 19:57
absoft for 4.06 or 4.08
from where i can get ABSOFT version compatible for 4.08 or 4.06
TomK August 2, 2010 11:02
Believe it or not, but we had to buy ours from CD-adapco. It turns out that STAR is not compatible with the latest version of ABSOFT FORTRAN. I don't know if you are personal (student) or commerical user, but STAR version 4.12 uses the intel FORTRAN compiler. So, I guess your choice is upgrade STAR-CD or downgrade your versio of FORTRAN.
TomK
mbilalm August 3, 2010 00:52
please advice me how to upgrade or get the 4.12 version that can perform well and can link to fortran compiler
i am a student and it is not at all a choice for me to buy
thanks
TomK August 3, 2010 12:39
The address to download version 12 is:
https://support.cd-adapco.com/faces/...te=9ypro71kd_4
This requires a user name and login, but if you are using it through your university, they should be able to provide it for you. Be sure to install everything, because it uses the latest flexlm license server to (the old license still works).
TomK
mbilalm August 4, 2010 22:01
thanks for ur attention to my problem
but i am studying in the university
previously my lab is not linked with CD-adapco
i am the new entry to use this tool
can u guide me further if i donot have the username & password
from where else i can get it 4.12 (complete with coding enabled)
mbilalm August 4, 2010 22:03
aaaaaaaaaaaaa
TomK August 5, 2010 16:20
CD-adapco has a program in the US for students to get their software for free:
http://www.cd-adapco.com/academic/university.html
If you are not in the US I have no advice.
TomK
mbilalm August 6, 2010 07:51
thank you very much for ur help
i am grateful to u for ur guidance,
unfortunately i am not in US i am in South Korea
i think i may not be able to find solution to this problem
thanks
TMG August 6, 2010 09:09
Even in South Korea, the local agent encourages university use. Ask your IT people to contact them. Its almost for sure available to universities at an attractive price
