March 26, 2009, 11:52 |
downwardly compatible
Rep Power: 16 |
Hello everybody.
Does anybody know, whether Star is downwardly compatible. Because at the moment we use Star CD V4.06 and when we want to open a .mdl file generated with Version 3.26 we achieve the message: **WARNING - FILE param.prp IS INCORRECT. IT COULD BE FOR A DIFFERENT VERSION OF pro-STAR. A NEW param.prp WILL BE WRITTEN AUTOMATICALLY BASED ON THE .mdl FILE BEING OPENED. **ERROR - NOT ENOUGH MEMORY CAN BE ALLOCATED. USE A SMALLER PARAM.PRP FILE OR A LARGER MACHINE. But the size of file param.prp is only 3kB. Thank you in advance mfg Luke |
March 26, 2009, 12:16 |
Anton Lyaskin
Rep Power: 17 |
First, try to delete param.prp file at all - ProSTAR will create a new one with default parameter values on opening then model and then try to adjust their values. Even if it fails, chances are that you'll get a more specific error message in this case, telling you what parameters shoukd be increased.
March 26, 2009, 12:23 |
Rep Power: 16 |
July 27, 2010, 03:13 |
tombur
hellow everyone..
i have a question with the way and steps for install star cd and ccm in windows 7 (x86 or install in x64). I ussually have a problem in running program. What star cd v4.08 is compatible for windows 7 ? thank you for your information |
July 27, 2010, 08:39 |
Robert
Rep Power: 16 |
Not sure about 4.08 but I have 4.12 running fine on Windows 7 64.
CCM+ 5.04 installs as well, for some earlier versions I think you have to turn on Vista compatibility. For both I was using the windows 64 bit version. |
Display Modes | |
Is Ansys compatible with Window Vista? If yes then | NITIN DEWANGAN | CFX | 2 | July 13, 2008 19:18 |
compatible linux and Starcd | zhihua | Siemens | 1 | March 14, 2008 09:21 |
Files Compatible with GAMBIT | David Banks | Main CFD Forum | 0 | July 10, 2007 10:15 |
AMD X2 & INTEL core 2 are compatible for parallel? | nikolas | FLUENT | 0 | October 5, 2006 07:49 |
Solidification X Compatible Phoenics Version | Henrique Argentieri | Phoenics | 2 | December 6, 2002 14:02 |
