Home > Forums > Software User Forums > Siemens > STAR-CD
calculate stop!
Old   September 9, 2010, 09:43
Default calculate stop!
zhang,wei
steven_1983 is on a distinguished road
i have opend a calculate in Star CD, but it calculates always to the same time step. Then it does not go ahead. But it seems still well. Like this:
FINISH TIME STEP NO. 1687
CPU TIME IS 1460.37 ELAPSED TIME IS 1637.06 MEMORY (DYNAMIC) USED IS 1738 MBYTES
---- ----------------------------------------------------- TIME STEP NO 1688 -----------------------------------------------------
1 3.73E-01 2.16E-02 1.45E-01-1.25E-03-3.67E-01 2.31E+02 8.91E+04 9.23E-01 5.01E+00 7.04E-01 4.41E+05 2.15E-01 1.55E+02 2.24E+02
0.00E+00 0.00E+00 2.81E-04 0.00E+00 0.00E+00 0.00E+00 0.00E+00 0.00E+00 0.00E+00 3.24E-01 0.00E+00 0.00E+00 0.00E+00 0.00E+00
2 -1.48E-02-2.04E-01-2.57E-02-1.88E-03-6.56E-02-1.01E+01-1.51E+03 -6.32E-01-8.93E-01-2.44E-01 1.69E+05 6.20E-01 3.70E+02 3.90E+02
0.00E+00 0.00E+00-1.88E-03 0.00E+00 0.00E+00 0.00E+00 0.00E+00 0.00E+00 0.00E+00 1.00E+00 0.00E+00 0.00E+00 0.00E+00 0.00E+00
3 -1.15E-01-2.22E+00-1.73E-01 1.04E-02-1.03E+00-2.04E+02 2.19E+03 1.58E+00 1.80E+00 4.72E-01 1.33E+05 1.16E+00 1.35E+03 7.22E+01
0.00E+00 0.00E+00 2.13E-03 0.00E+00 0.00E+00 0.00E+00 0.00E+00 0.00E+00 0.00E+00 2.25E-01 0.00E+00 0.00E+00 0.00E+00 0.00E+00
FINISH TIME STEP NO. 1688
CPU TIME IS 1633.46 ELAPSED TIME IS 1814.68 MEMORY (DYNAMIC) USED IS 1738 MBYTES
steven_1983 is offline   Reply With Quote
Old   September 14, 2010, 15:00
Tom Keheley
TomK is on a distinguished road
I am not sure what I am looking at here, the output of the run file or the info file.
However, not knowing something will not keep me from trying an answer. Usually in STAR-CD if the run stops it is for one of three reasons: 1) an error occurred, 2) you have reached the maximum number of iterations specified, or, 3) you have reached your tolerance on the residuals. Since there is no error message given, I would investigate nos. 2 & 3.
Tom
TomK is offline   Reply With Quote
Old   September 15, 2010, 03:35
zhang,wei
Thank you all the same! I have solved the problem. I have only a little change the spraydirection.
Transient DPM-About Start Stop times Julie FLUENT 3 January 24, 2014 07:39
how to calculate flow properties along the first grid point near to the wall kiran OpenFOAM Post-Processing 2 September 12, 2010 12:59
calculate values for eps and k from Re or u????? sbar OpenFOAM Pre-Processing 5 August 16, 2010 04:10
How to calculate Torque for francis turbine manish CFX 4 March 15, 2007 02:57
How to calculate energy dissipation chinthakindi Main CFD Forum 0 February 23, 2004 06:36
