Home > Forums > STAR-CD
restart after changing boundary conditions
Old   April 12, 2011, 17:19
Smile restart after changing boundary conditions
Antonella
aperrone is on a distinguished road
hello everyone!
I'm moving from starcd 4.06.007 to starcd 4.14.008, and I have some problems with the restart after changing the boundary conditions:
in particular I change some boundaries from wall to inlet conditions and then I restart the run. The material within the domain is air, and everything works if at the inlet I employ for instance CH4 or air, while employing H2 I got this strange error message (I use the polynomial treatment for the specific heat ):
*** Error 615: Negative Gamma, please check if Cps are right
RUN STOPPED !!!
If instead I use an air-H2 mixture with low H2 content the run restarts without any problems. I checked the polynomial coefficient and they're right, they're the same employed in the 4.06.07 version with which the same restart was working.
Has anyone experienced this error and knows the reason why it occurs, or could provide me any advice to settle it?
thanks in advance for your help
Antonella
aperrone is offline   Reply With Quote
Old   April 13, 2011, 08:53
Robert
RobertB is on a distinguished road
Are all your scalar fractions correctly bounded (i.e. between 0 and 1)?
RobertB is offline   Reply With Quote
Old   April 13, 2011, 11:06
Antonella
I think they are, in fact with a H2 scalar fraction inferior to 0.2 the run restarts, instead with higher H2 scalar fraction, for example 0.7 or 1, I got that error message, and this happens only with hydrogen: other scalars work fine.
Old   April 13, 2011, 11:53
Robert
Star uses mass fractions not volume fractions. Hydrogen is light thus a 0.7 mass fraction is more or less a 100% volume fraction.
Perhaps this has something to do with the problem. Perhaps it goes slightly unbounded and that causes a problem, what differencing scheme are you using?
Old   April 13, 2011, 13:11
Antonella
I also think that the fact that hydrogen is extremely lighter than air deals with the problem, but I need to inject pure hydrogen and I think this means necessarily mass fraction equal to one, otherwise I'd inject a lower mass of hydrogen, a H2-air mixture, are you in agreement, or I'm making a mess?
I was also thinking that CH4 is lighter than air too, but with a scalar fraction equal to one works well, so do you know how star treats this volume fraction bigger than 100%?
For the scalars I'm using the upwind scheme, please, could you suggest me something more robust?
Old   April 25, 2011, 20:53
SMM
Syed Murtuza Mehdi
SMM is on a distinguished road
I think if one wants to change/edit the model then one needs to save the problem file again and then run the solver.
SMM is offline   Reply With Quote
Thread Tools
Trackbacks are On
Boundary Conditions Thomas P. Abraham Main CFD Forum 20 July 7, 2013 05:05
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
CFX doesn't continue calculation... mactech001 CFX 6 November 15, 2009 22:25
Water vapour condensation in CFX-5.7.1 hdj CFX 1 November 27, 2005 08:15
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
