Home > Forums > Software User Forums > Siemens > STAR-CD
Problem about using es-ice
Old   June 24, 2011, 05:25
Default Problem about using es-ice
Shiyu Zhou
mic0126 is on a distinguished road
I want do the engine CFD simulation by star-cd.
Now I made a geometry by catia, and put into the es-ice to create the template.
Finish creating the template I mapping the template with the geometry.
When finish the mapping, I checked the negative volume.If it existing,I smooth again.(sometimes I smooth so many times but the negative volume still exist,is there any way to make it easier).When I finish the mapping and also check the negative volume is 0.Then I use star setup to create the moving mesh.After that I created the result at TDC to check the negvol still exist.At this time hundereds of negative exist around the valve.This problem confused me so many days.Is anyone could give me some hint to solve this problem?
mic0126 is offline   Reply With Quote
Old   July 14, 2011, 07:22
AB
chili023 is on a distinguished road
why do u mapp.
Is it a very complicated geometry?
chili023 is offline   Reply With Quote
area does not match neighbour by ... % -- possible face ordering problem St.Pacholak OpenFOAM 10 February 7, 2024 21:50
conduction problem venkataramana OpenFOAM 3 December 1, 2013 07:30
Problem in implementing cht tilek CFX 3 May 8, 2011 08:39
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
