Meshing of a sharp edge orifice with a radius
Hi, I am trying to mesh a sharp edge orifice that has a radius between the 2 cylinders.
http://imageshack.us/photo/my-images...dgeradius.gif/ Here is a zoom of the sharp edge. I made the radius by moving some vertices to create a radius, but I am concerned about the non-smooth transition between the angles of my cells. Do you guys have any ideas how could I have a better mesh around the radius. I want to keep the rest of my mesh as quad cells. Thank you |
Try to understand the following prostar-code. It tells you how to create a wall parallel sublayer on an existing mesh.
vc3d 0 1 20 0 1 20 0 1 20 |
Hi, thanks for answering, but I'm not sure you understand what I need.
I need to make a sharp edge that consists 2 cylinders joined together and I need to make a radius so there is no more sharp edge. I just want to have a smooth mesh where my radius is |
1 Attachment(s)
A wall layer is usefull for sharp edges and also for a radius. You can smooth the mesh later using the "vell" and "vsmoo" comands.
