equivalence ratio calculation on star-cd cell |
April 10, 2012, 05:32 |
Krishna
Rep Power: 14 |
Can you please help me in equivalence ratio calculation over computational domain. the fuel is -> C8H18. my main problem is how to calculate the c8h18 for each cell over domain. Thanks in advance. regards, Krishna |
April 10, 2012, 20:52 |
zheng jianjun
Rep Power: 16 |
please try this macro, bless.
*set,safr, 15.03442884 !stoichiometry air fuel ratio of iC8H18-kg/kg operate,getc,conc,1,1 !the mass fraction of fuel vapor ! operate,getc,conc,2,2 !the mass fraction of oxygen-- ! operate,smultiply,4.291845494,2,3 !the mass fraction of air in the cell=m_O2/0.233 operate,divide,1,3,5 !F/A =fuel air ratio operate,smultiply,safr,5,4 !phi=F/A*sto_A/F spoint 0 0 0 snormal 0 1 0 ! poption,contour ! pltype,section ! angle 0 ! view snormal ! cplot |
April 11, 2012, 01:04 |
Krishna
Rep Power: 14 |
Thank you very much..
Can you please explain the below points: 1. why u are multiplying oxygen with 4.291845494. this is how cell data stored { CELL DATA SU "Velocity Component U" m/s SV "Velocity Component V" m/s SW "Velocity Component W" m/s MassFlux "Mass Flux" kg/s P "Pressure" Pa PTER "Thermo. Pressure" Pa TE "Turb Kinetic Energy" m2/s2 ED "Dissipation Rate" m2/s3 VIS "Turbulent Viscosity" Pa s T "Temperature" K H "Enthalpy" J/kg DENS "Density" kg/m3 CP_M "Mean Specific Heat" J/kgK CP "Specific Heat" J/kgK COND "Conductivity" W/mK CONC_001 "C8H18" CONC_002 "N2" CONC_003 "O2" CONC_004 "WFMASS" CONC_005 "WFTHICK" CONC_006 "WFTEMP" CONC_007 "RG" VOID "Void Fraction" } 2. please check the above commands once. operate,getc,conc,2,2 !the mass fraction of oxygen-- now i have to run it as a operate,getc,conc,2,3 !the mass fraction of oxygen-- can you please conform this. Thanks in advance. Last edited by kri321shna; April 11, 2012 at 02:38. |
April 11, 2012, 03:43 |
zheng jianjun
Rep Power: 16 |
Q1. why u are multiplying oxygen with 4.291845494.
answer: 4.291845494=1/0.233, multiplying oxygen with this value, you can get the mass fraction of air. Q2. please check the above commands once. operate,getc,conc,2,2 !the mass fraction of oxygen-- now i have to run it as a operate,getc,conc,2,3 !the mass fraction of oxygen-- Answer: It is all right that you made a small modification as "operatre,getc,conc,2,3",due to the last number stands for "species number", and second to last number represents "register number". --------------------------------------------------------------------------------------------------------------------------------------------------- operate GETC CONC,IREGS,NSC(1) ==Loads the mass fractions of scalar species NSC into register IREGS. CONC_001 "C8H18" CONC_002 "N2" CONC_003 "O2" Last edited by skylent; April 11, 2012 at 04:06. |
April 11, 2012, 05:34 |
Krishna
Rep Power: 14 |
thank you so much ...
i have checked the operate command like.. operate,getc,conc,2,3 here 2 is the register and 3 is the conc value. Thank you ... |
Exporting Cell set from STAR CCM+ | vishyaroon | STAR-CCM+ | 0 | July 13, 2009 14:47 |
Air Fuel Ratio Calculation. | Yee-Hern.Tan | FLUENT | 0 | February 25, 2009 08:07 |
Problem of Turbulent Viscosity Ratio Limited | David Yang | FLUENT | 3 | June 3, 2002 06:13 |
Calculation of cell areas in USRTRN | S๘ren | CFX | 1 | May 7, 2002 11:59 |
Calculation of cell volume and face handedness | Mark | FLUENT | 0 | August 30, 2001 07:45 |
