Home > Forums > General Forums > Structural Mechanics
No convergence method available in ANYS FSI problems?
Old   May 10, 2013, 07:54
Default No convergence method available in ANYS FSI problems?
acasas's Avatar
Antonio Casas
acasas is on a distinguished road
Hi , I canīt add a convergence method on a FSI problem. A pressure solution from CFX fluid analisis is beeing aplyied over a wing shaped structure as a load. When I try to add the convergence method under solution options in mechanical workbench, this option is not availabe.
If I do supress the imported pressure, and add a simple force load on the tip of the wing shaped structure, then this option is available and I can use this convergence method.
Can someone tell me why?
Thankīs a lot
acasas is offline   Reply With Quote
Old   May 10, 2013, 08:10
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
http://www.cfd-online.com/Forums/ans...workbench.html
Far is offline   Reply With Quote
Old   May 10, 2013, 08:28
acasas's Avatar
Antonio Casas
mmm, donīt understand. Why 2 way? iīts 1 way in my case.
thankīs
Old   May 10, 2013, 08:32
acasas's Avatar
Antonio Casas
by the way, I see my post have been moved. How to find where? And why itīs beeing moved? I have posted under Ansys forum directory, isnīt the right way to do it?
Thankīs
Old   May 10, 2013, 09:02
Far
Sijal
acasas: Your thread has been moved to CFX forum for one week. Here you will meet wonderful people who are expert in FSI with CFX specially Glenn.
Old   May 10, 2013, 23:53
Sorry, I am no expert on FSI. In fact I will admit that I have never done an FSI simulation with CFX as I do not need to in my line of work But I do know a little about CFD and numerical methods in general and many of the questions asked are simple enough for that.
Old   May 11, 2013, 04:46
acasas's Avatar
Antonio Casas
Sad for me.
Where can I find help for this? Any suggestion?
Old   May 11, 2013, 04:53
Far
Sijal
I am sending you some tuts on FSI using CFX. Hope it will help you.
uploading will take some time around 12-14 hrs
Old   May 11, 2013, 05:14
acasas's Avatar
Antonio Casas
Hi Sijal. Thanks for it.
I do more or less know how to solve a FSI 1 way problem.
But as I told you, my problem now is inside mechanical workbench. If I do apply a pressure solution as a load to my structure, I CAN get the stress over it with no problem. However if I try to use the convergence method for a better automatic mesh refinement on the higly stressed areas, this option does NOT show up. Instead, if I do apply a simple force on the tip of my wing shaped structure and supress the imported pressure, the convergence option does show up.
Any suggestion?
Thankīs
Old   May 11, 2013, 05:50
Far
Sijal
What do you mean by convergence?
http://www.padtinc.com/blog/the-focu...al-information
Old   May 12, 2013, 14:29
Far
Sijal
downloaded files?
Old   May 12, 2013, 14:39
acasas's Avatar
Antonio Casas
Hey Sijal!
Just downloading right now. thankīs
force convergence problems in CFX 6DOF rigid body solver ajay_ks CFX 8 March 25, 2013 04:02
Implicit method of FSI cjtune Siemens 0 March 12, 2003 12:07
convergence problems david aquilina Siemens 4 October 27, 2000 09:18
convergence acceleration by preconditioning method Atit Koonsrisuk Main CFD Forum 4 June 5, 2000 06:21
Has the pressure correction method problems? X. Ye Main CFD Forum 17 September 1, 1999 16:14
