Home > Forums > Structural Mechanics
FSI,Workbench-static structural,fluent
Old   September 2, 2013, 11:49
Default FSI,Workbench-static structural,fluent
Ali.E
behest is on a distinguished road
Hello my friends,
I am trying to simulate FSI by workbench ansys. the goal is to obtain stress and strain of a 3D wing. Therefore, I used fluent and static structural in workbench. Fluent simulation is done very well, but I have a problem to run static structural.
In the structural, I imported just the wing (without flow domain) and after generating mesh, it is needed to import pressure data;
Project>Model>Static Structural>Imported Load (Solution) >Imported Pressure
I did it but I recieved an error.
error:
An error occurred while trying to read the CFD result file. Please delete the load and try again.
Could anybody help me? Have you any experiance about it?
Do you have any toturial that solved FSI around a wing?
behest is offline   Reply With Quote
Old   October 19, 2015, 21:12
Default Same problem
Peter
Peter88 is on a distinguished road
I got the same problems, you have found a solution for this?
Peter88 is offline   Reply With Quote
Old   November 12, 2015, 02:35
Tanmay Inamdar
Tanmay95 is on a distinguished road
Check if you have assigned material for wing. (Geometry part is well defined and have a tick next to your wing geometry)
Tanmay95 is offline   Reply With Quote
Thread Tools
Trackbacks are On
UDF issue MASOUD Fluent UDF and Scheme Programming 14 December 6, 2012 14:39
error: uninitialized local variable 't' used MASOUD Fluent UDF and Scheme Programming 3 November 26, 2012 06:24
fprint problem MASOUD Fluent UDF and Scheme Programming 5 October 30, 2011 17:08
defining a term for a domain using DEFINE_ADJUST MASOUD Fluent UDF and Scheme Programming 1 September 24, 2010 05:08
enum MASOUD Fluent UDF and Scheme Programming 0 June 5, 2010 00:49
