Home > Forums > General Forums > Structural Mechanics
Sphere Deformation Simulation
Old   December 23, 2013, 05:43
Post Sphere Deformation Simulation
Milad
amingh is on a distinguished road
I am trying to simulate the deformation of a sphere which is placed between 2 cylindrical plates and is in contact with them. The plate in the bottom is fixed by FIXED SUPPORT and the plate on the top is under a SURFACE FORCE. I want to simulate the deformation of the sphere. I have couple of questions:
1. How can I give different mechanical data such as young's modules for each of the 3 bodies SEPARATELY? because I don't want the whole geometry to have the same mechanical properties.
2. Since everything is symmetric in my simulation, I expect to have symmetric results, but as you can see in results I get some deformation in the top plate which is not symmetric, I wonder why it is like that????
Thanks for any help
amingh is offline   Reply With Quote
Old   December 23, 2013, 07:10
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
Your physical model may be symmetric, but your computational model is not.
With the Boundary conditions you described so far, your model is under-constrained and Ansys will add weak springs to prevent the solution from diverging.
You have to add boundary conditions to your model to make fully-constrained.
A simple solution would be to actually make use of the symmetry and model only a segment of the full model. With symmetry boundary conditions at the new boundaries you can already constrain some degrees of freedom which should be enough to make the model fully constrained.
flotus1 is offline   Reply With Quote
Old   December 23, 2013, 07:19
Milad
Thanks for your answer, I just wanted to fix the displacement of the plate to prevent it from deformation, but it didn't work.
Old   December 24, 2013, 08:16
Milad
I have fixed the problem with symmetric deformation, but still I do not know how to give different mechanical properties for each part separately, for example mechanical properties of gold for the sphere and diamond for the plates. (I am using static structural toolbox in ANSYS.)
Old   February 28, 2014, 03:52
Florin's Avatar
Florin Gheorghe
Florin is on a distinguished road
Hello amingh,
You just have to create the materials in Engineering Data (you must know the properties) and when in Mechanical, you can assign them to the desired geometry.
Best regards,
Florin
Florin is offline   Reply With Quote
ansys, deformation, fea, mechanical, sphere
simulation of free falling sphere into calm water? pedyspider CFX 17 June 25, 2015 11:03
a simulation with rotation and vibration liuzexiang CFX 34 September 16, 2013 08:12
Convergence of jet flow simulation MiraLisa FLUENT 0 August 15, 2013 04:44
Requiring some help regarding tornado simulation amarjogot Main CFD Forum 0 June 20, 2013 12:26
Spinning sphere simulation Herry CFX 1 May 24, 2003 09:33
