August 19, 2014, 12:05 |
static
majid
Rep Power: 11 |
can anyone help me for this problem
http://www.cfd-online.com/Forums/cfx...ory-alloy.html |
August 23, 2014, 04:09 |
Raj
Rep Power: 11 |
Hi
If your intention is to analyze the pipe material, you should use a SMA model for pipe only and do it using ANSYS Mechanical rather than doing it in any CFD code. SMA is normally superelasticity materials. You may refer help in to the ANSYS guide and search for "Shape Memory Alloy". There is a superelasticity material model available. If you like my answer, please like my tweets,blogs by visiting my website www.desservees.com We have a lot of case study material available. You may download from there. Regards, Rajendra, www.desservees.com cfd@desservees.com |
error: uninitialized local variable 't' used | MASOUD | Fluent UDF and Scheme Programming | 5 | October 17, 2016 04:24 |
UDF issue | MASOUD | Fluent UDF and Scheme Programming | 14 | December 6, 2012 13:39 |
fprint problem | MASOUD | Fluent UDF and Scheme Programming | 5 | October 30, 2011 16:08 |
defining a term for a domain using DEFINE_ADJUST | MASOUD | Fluent UDF and Scheme Programming | 1 | September 24, 2010 05:08 |
enum | MASOUD | Fluent UDF and Scheme Programming | 0 | June 5, 2010 00:49 |
