January 12, 2016, 03:46 |
Nonlinear Adaptive Meshing in ANSYS R15
Pranjal Singh
Rep Power: 10 |
Hi there!
I'm using ANSYS Workbench Mechanial R15. I read in the manual that I can use NLADAPTIVE command to get adaptive remeshing for (high deformation) nonlinear analysis. I added this command snippet (same as described in an example in the manual) but it won't work. Am I missing something? I inserted The Large Deflection ON above, below and in middle of the code and it works fine. So I guess the solver does take note of the whole command. Code:
! Component Making esel,all cm,cmall,elem ! Large Deflection ON nlgeom,on ! Nonlinear adaptivity criteria nladaptive,cmall,add,energy,mean,0.01 ! Nonlinear adaptivity toggle ON for every substep nladaptive,cmall,on,,,1 Last edited by PranjalNewton; January 12, 2016 at 03:49. Reason: more info |
adaptive mesh, nladaptive |
adaptive meshing | clifford bradford | Main CFD Forum | 14 | September 3, 2022 19:13 |
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 10:49 |
Using ICEM CFD to repair/edit ANSYS Meshing | Kaaji1359 | ANSYS | 2 | July 30, 2013 10:28 |
2d meshing in ansys meshing | syler3321 | ANSYS Meshing & Geometry | 10 | November 1, 2012 20:42 |
How To save a created mesh file in Ansys Meshing | ashtonJ | CFX | 4 | January 7, 2012 22:04 |
