Home > Forums > SU2 Installation
Windows 7 parallel calculations
Old   March 8, 2013, 06:19
Cean
shirazbj is on a distinguished road
Originally Posted by curky View Post
Yes, finally works!!! Great job. It will be good to include this solution in the next release of SU^2.
I tried the new Rev1206.zip, it is working. It corrected the big array: it[MAX_NUMBER_DOMAIN][MAX_NUMBER_DOMAIN] in
void CPhysicalGeometry::SetSendReceive(CConfig *config)
shirazbj is offline   Reply With Quote
Old   May 10, 2013, 02:33
horizon b.
horizon is on a distinguished road
Dear SU2 Developers
i am new for SU2 solver. I have installed parallel version of win7-64 bit from this site Windows 7 Parallel Installer (64 bit): http://su2.stanford.edu/download/v2....x64-MPICH2.exe and mpich2.1.4.1p-1. I have tested the example in mpich and it is working. But when i try to run SU2_DDC parallel in command prompt,i have encountered that "SU2_DDC.exe has stopped working."
D:\SU_2\TestCases\rans\s809\deneme>SU2_DDC turb_s809.cfg
WARNING: unrecognized option in the config. file: ONESHOT_CAUCHY_EPS.
| SU2 Suite (Domain Decomposition Code) |
------------------------ Physical case definition -----------------------
Input mesh file name: naca0012_00106_y40.su2
-------------------------- Output information ---------------------------
Don't visualize the partitions.
------------------- Config file boundary information --------------------
Navier-Stokes wall boundary marker(s): airfoil.
Far-field boundary marker(s): farfield.
---------------------- Read grid file information -----------------------
Two dimensional problem.
15228 interior elements. 15552 points.
2 surface markers.
324 boundary elements in index 0 (Marker = airfoil).
324 boundary elements in index 1 (Marker = farfield).
----------------------- Preprocessing computations ----------------------
Identifying vertices.
---------------------- Performing mesh partitioning ---------------------
Finished partitioning using METIS 5.0.2. (380 edge cuts).
If i write like that, again it gave error.
D:\SU_2\TestCases\rans\s809\deneme>mpiexec -n 4 SU2_DDC.exe turb_s809.cfg
15552 points.
60912 interior elements (incl. halo cells). 0 points (incl. ghost points)
job aborted:
rank: node: exit code[: error message]
0: T12011114350: -1073741571: process 0 exited without calling fina
lize
1: T12011114350: -1073741571: process 1 exited without calling fina
lize
2: T12011114350: -1073741571: process 2 exited without calling fina
lize
3: T12011114350: -1073741571: process 3 exited without calling fina
lize
I am missing something? Please help.
horizon is offline   Reply With Quote
Old   May 12, 2013, 02:32
Cean
[QUOTE=horizon [url]http://su2.stanford.edu/download/v2.0/Setup-Windows_x64-MPICH2.exe[/url]
Is this the old 2.0?
U need use the newest 2.0.3 version.
Thread Tools
Trackbacks are On
CFX Parallel Setup on windows 7 x64 SlicedBread CFX 1 November 14, 2011 17:06
Parallel run of OpenFOAM in linux and windows side by side m2montazari OpenFOAM Running, Solving & CFD 5 June 24, 2011 03:26
FLUENT in Windows Serial and Linux Parallel sham83 FLUENT 0 May 31, 2011 23:38
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
MPICH Parallel Run Error on the Windows Server2003 Saturn CFX 3 August 29, 2006 08:42
