July 16, 2014, 00:01 |
Starting trouble.
Rep Power: 13 |
I'm new to SU2. I downloaded win7 64bit version and installed. The problem is I'm not getting how to start it..
Any help would be appreciated. |
July 16, 2014, 06:53 |
Selmar
Rep Power: 11 |
I recommend you follow the quick start tutorial.
You can run SU2 by entering commands in the command prompt (cmd.exe from the start menu). In order for windows to find the SU2 executables, the SU2 directory should be in your PATH environment variable (check if it is, it wasn't for me). |
July 17, 2014, 00:52 |
Rep Power: 13 |
I tried using the path but Cmd is saying that " There is no configuration file!"..
July 17, 2014, 05:38 |
#4 | |
Selmar
Rep Power: 11 |
Did you give a configuration file as an argument?
SU2 has no GUI or anything, it runs completely from the command line. From the quick-start tutorial (http://adl-public.stanford.edu/docs/display/SUSQUARED/Quick+Start+Tutorial): Quote:
July 18, 2014, 00:59 |
Rep Power: 13 |
OK I understood but where I could find the inv_NACA0012.cfg and mesh_NACA0012_inv.su2 files?
July 18, 2014, 10:30 |
Selmar
Rep Power: 11 |
There are links to the files in the tutorial..
July 20, 2014, 03:40 |
Rep Power: 13 |
Thank you Selmar
July 21, 2014, 01:38 |
Rep Power: 13 |
How to use this file using SU2?. I'm confused..
Thanks, Shivakumar |
July 21, 2014, 07:10 |
#9 |
Selmar
Rep Power: 11 |
That file looks like a part of a mesh? The mesh file itself is used by SU2 through the config file.
July 21, 2014, 12:30 |
#10 |
Rep Power: 13 |
Indeed Selmar .. When I run the file "mesh_NACA0012_inv.su2" in command window I got that answer and struck in results part.
I'm planning to go for 3D wing now. Is it possible to create a geometry, domain etc. using SU2.? Inform me step by step.. Thanks, Shivakumar |
July 21, 2014, 12:52 |
#11 |
Selmar
Rep Power: 11 |
Running the mesh file? How? From what I know, mesh files are used by SU2 only through the configuration files. The config files have the mesh name and define the boundary conditions and other parameters. The CFD code looks through the config file, finds the mesh name, loads the mesh and uses it to solve the equations on.
You can create meshes for SU2 with Pointwise, it has an SU2 plugin. I am just an SU2 beginner, just like you. I'm not here to give you step-by-step information on how to accomplish things like that, even if I could - I advise you to read the documentation a bit more thoroughly. Most notably, look through the tutorials. They contain a lot of information. |
big difference between clockTime and executionTime | LM4112 | OpenFOAM Running, Solving & CFD | 21 | February 15, 2019 03:05 |
[OpenFOAM] XYZ starting points of streamtraces in Paraview | deniggo | ParaView | 3 | May 22, 2013 03:02 |
[GAMBIT] Trouble meshing complex VOF geometry | RPJones | ANSYS Meshing & Geometry | 2 | February 14, 2011 18:54 |
Trouble in starting FoamX | ishimotoj | OpenFOAM Pre-Processing | 4 | November 7, 2006 08:45 |
Lamboot trouble | r2d2 | OpenFOAM Installation | 4 | October 17, 2005 04:27 |
