Home > Forums > Software User Forums > SU2 > SU2 Installation
SU2 2.0.6 test case execution errors
Old   September 3, 2013, 12:55
Default SU2 2.0.6 test case execution errors
Austin Murch
austin.m is on a distinguished road
I've compiled SU2 v2.0.6 from the github on Ubuntu 12.04, using Metis v5 and openMPI. I'm running Ubuntu via VirtualBox on a Windows 7 machine.
I'm running into the following errors:
1. When trying to run the /SU2-2.0.6/TestCases/euler/onearam6 test case in serial I get:
ERROR: Cannot find value LU_SGS in given map.
2. When I try to run this case in parallel using "parallel_computation.py" I get:
AssertionError: Config file has multiple specifications of DV_VALUE_OLD
Thanks in advance!
austin.m is offline   Reply With Quote
Old   September 3, 2013, 16:25
Austin Murch
Update:
1. Caused by incorrect specification of the LINEAR_SOLVER parameter in the cfg file. Was able to fix by copying "config_template.cfg" from /SU2-2.0.6/. This problem appears throughout the TestCases configuration files.
2. Appears to be stemming from config files generated by python scripts; parameters implicated are DV_VALUE_OLD, DV_VALUE_NEW, and DV_VALUE. The python scripts seem to ignore any values for these parameters in the base config file and fail to write any values in the auto-generated config files. If I manually edit the auto-generated config files after the fact, I can get SU2_DDC and SU2_CFD to run, but this defeats the purpose of the python scripts...
Old   September 3, 2013, 17:09
Austin Murch
Grabbed a fresh copy of 2.0.6 from the github, and found all config files have the proper LINEAR_SOLVER specifications and the DV_VALUE issue resolved as well. Not sure what happened with the first copy of 2.0.6 I was working with...
Old   October 3, 2013, 14:44
Francisco Palacios
fpalacios is on a distinguished road
Hi Austin,
Yep, we are reorganizing the config options for the new release. We always update the configuration_template.cfg, and those cases that are in our regression test system.
Thanks for using SU2,
Best
Francisco
fpalacios is offline   Reply With Quote
Old   October 4, 2013, 09:30
Default rans/rae2822 test case v2.0.8
Tom Jentink
jentink is on a distinguished road
I had the base stable version installed (v2.0) and ran a few test cases with no problems.
Last night I installed the latest from github (2.0.8) and the new testcase directory. I've been trying to run the rae2822 airfoil case (in rans directory) and it core dumps w/out any helpful information.
any idea where to look for the problem?
jentink is offline   Reply With Quote
Large test case for running OpenFoam in parallel fhy OpenFOAM Running, Solving & CFD 23 April 6, 2019 09:55
Problem with plasma test case: residuals are NAN rafpepe SU2 2 January 20, 2013 09:37
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
Interfoam Droplet under shear test case adona058 OpenFOAM Running, Solving & CFD 3 May 3, 2010 18:46
c1 body test case Eric Lenormand Main CFD Forum 0 March 2, 2000 06:54
