Home > Forums > Software User Forums > SU2 > SU2 Installation
Grid partitioning error.
Old   August 30, 2013, 04:29
Post Grid partitioning error.
Akash Chaudhari
Akash C is on a distinguished road
I have compiled the latest version of the code from github and was trying to run the DPW tutorial in parallel. During the partitioning of grid the following error crops up.
------------------------ Divide the numerical grid ----------------------
Finished partitioning using METIS 4.0.3. (73515 edge cuts).
Domain 1: 796503 points (18642 ghost points). Comm buff: 72.35MB of 50.00MB.
Traceback (most recent call last):
  File "parallel_computation.py", line 109, in <module>
    main()
  File "parallel_computation.py", line 54, in main
    options.divide_grid  )
  File "parallel_computation.py", line 77, in parallel_computation
    info = SU2.run.decompose(config)
  File "/home.local/akash.chaudhari/Analysis/ver2.0.6/SU2/run/decompose.py", line 66, in decompose
    SU2_DDC(konfig)
  File "/home.local/akash.chaudhari/Analysis/ver2.0.6/SU2/run/interface.py", line 68, in DDC
    run_command( the_Command )
  File "/home.local/akash.chaudhari/Analysis/ver2.0.6/SU2/run/interface.py", line 272, in run_command
    raise Exception , message
Exception: Path = /home.local/akash.chaudhari/Analysis/ver2.0.6/,
Command = mpirun -np 2 /home.local/akash.chaudhari/SU_CFD/SU2v2.0.6/SU2/SU2_PY/bin/SU2_DDC config_DDC.cfg
SU2 process returned error '1'
Fatal error in MPI_Bsend: Invalid buffer pointer, error stack:
MPI_Bsend(182).......: MPI_Bsend(buf=0x7f065aeb1010, count=6161488, MPI_UNSIGNED_LONG, dest=0, tag=7, MPI_COMM_WORLD) failed
MPIR_Bsend_isend(305): Insufficient space in Bsend buffer; requested 49291904; total buffer size is 52430000
So does this mean that I have to move to bigger machine or possibly a cluster to run this analysis as there is memory shortage. This mesh has cell count of 1.5 million and I had run meshes of cell count up to 1.2 million on my current machine with older versions of the code.
Kindly help me solve this problem.
Thanks,
Akash
Akash C is offline   Reply With Quote
Old   September 6, 2013, 12:43
Austin Murch
austin.m is on a distinguished road
I have also encountered this error when trying to partition a very large grid.
"Comm buff: 130.80MB of 50.00MB"
The machine I am running on has 96GB of RAM, so I doubt it is a machine memory issue.
austin.m is offline   Reply With Quote
Old   September 6, 2013, 14:37
Austin Murch
Line 117 of ../Common/include/option_structure.hpp has
const unsigned int MAX_MPI_BUFFER = 52428800; /*!< \brief Buffer size for parallel simulations (50MB). */
I increased this value to 150MB and the partitioning process gets a little farther (to domain 3 of 8), but then still errors out:
[CFD-LINUX:22185] *** An error occurred in MPI_Bsend
[CFD-LINUX:22185] *** on communicator MPI_COMM_WORLD
[CFD-LINUX:22185] *** MPI_ERR_BUFFER: invalid buffer pointer
[CFD-LINUX:22185] *** MPI_ERRORS_ARE_FATAL (your MPI job will now abort)
Old   September 6, 2013, 15:23
Austin Murch
After googling "MPI_ERR_BUFFER: invalid buffer pointer", it seems the buffer was still not big enough. So I boosted the MAX_MPI_BUFFER to 1.5 GB, and now my 22M element grid will partition successfully.
SU2 developers: what should this buffer be set to? The maximum grid size we expect? For the record, this 22M element grid is 1.8 GB on the disk in *.su2 format.
Old   September 7, 2013, 00:40
Post
Akash Chaudhari
Thanks for your replies Austin. I will try this out on my machine.
[OpenFOAM] Python script to export animation images mahyarv14 ParaView 10 August 16, 2014 11:11
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 03:23
"No module named libSU2" in py script shirazbj SU2 Installation 3 February 9, 2013 09:12
fireFoam.1.7.x_0.4 compilation error !link OpenFOAM Installation 9 December 24, 2012 04:15
[General] SurfaceFlow filter in python script yohey ParaView 2 March 18, 2012 07:43
