Home > Forums > Software User Forums > SU2 > SU2 Installation
checking for C++ compiler default output file name... configure: error: C++ compiler
Old   September 6, 2013, 11:55
Default checking for C++ compiler default output file name... configure: error: C++ compiler
dhxlxz is on a distinguished road
./configure
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking for g++... g++
checking for C++ compiler default output file name... a.out
checking whether the C++ compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking for style of include used by make... GNU
checking dependency style of g++... gcc3
checking for ranlib... ranlib
configure: creating ./config.status
config.status: creating Makefile
config.status: creating trunk/Common/lib/Makefile
config.status: creating trunk/SU2_CFD/bin/Makefile
config.status: creating trunk/SU2_DDC/bin/Makefile
config.status: creating trunk/SU2_GPC/bin/Makefile
config.status: creating trunk/SU2_MAC/bin/Makefile
config.status: creating trunk/SU2_MDC/bin/Makefile
config.status: creating trunk/SU2_PBC/bin/Makefile
config.status: creating trunk/SU2_SMC/bin/Makefile
config.status: creating trunk/SU2Py/Makefile
config.status: executing depfiles commands
Build Configuration Summary:
Source code location: /home/**/SU2v2.0
Install location: /usr/local
Version: 2.0
Compiler: g++
Preprocessor flags:
Compiler flags: -DNO_MPI
Linker flags:
CGNS support: no
MPI support: no
Metis support: no
Build SU2_CFD: yes
Build SU2_DDC: yes
Build SU2_GPC: yes
Build SU2_MAC: yes
Build SU2_MDC: yes
Build SU2_PBC: yes
Build SU2_SMC: yes
Please be sure to add the $SU2_HOME and $SU2_RUN environment variables, and update your $PATH with $SU2_RUN
there is no problem! as i configure with ./configure --with-CGNS-lib=/usr/local/lib --with-CGNS-include=/usr/local/include --with-Metis-lib=/usr/local/lib --with-Metis-include=/usr/local/include --with-Metis-version=5 --with-MPI=/usr/local/bin
i got the output
checking for /usr/local/lib/libcgns.a... yes
checking for /usr/local/include/cgnslib.h... yes
checking for /usr/local/lib/libmetis.a... yes
checking for /usr/local/include/metis.h... yes
See `config.log' for more details.
The versions are mpich-3.0.4, cgnslib_3.1.4-2, metis-5.1.2, what is the matter???
Last edited by dhxlxz; September 6, 2013 at 12:04. Reason: add some more information
dhxlxz is offline   Reply With Quote
Old   September 6, 2013, 14:49
Austin Murch
austin.m is on a distinguished road
When you specify the MPI option, you need to have the compiler specified, e.g.:
--with-MPI=/usr/local/bin/mpicxx
austin.m is offline   Reply With Quote
Old   September 7, 2013, 11:08
Thumbs up nice answer
Hi, austin.m, thank you very much for your kind reply. It has been installed.
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 17:18
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 08:48
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 03:01
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
Gerris software installation mer Main CFD Forum 2 November 12, 2005 08:50
