Adaptive Mesh Refinement. Paraview is impossible? |
June 2, 2013, 07:03 |
I get error
Traceback (most recent call last): File "./mesh_adaptation.py", line 387, in <module> main() File "./mesh_adaptation.py", line 59, in main options.save_all ) File "./mesh_adaptation.py", line 150, in mesh_adaptation parallel_computation( Config_CFD_filename, partitions ) File "/home/ec2-user/SU2_bin/bin/parallel_computation.py", line 95, in parallel_computation info = SU2.run.merge(config) File "/home/ec2-user/SU2_bin/bin/SU2/run/merge.py", line 71, in merge merge_surface(konfig) File "/home/ec2-user/SU2_bin/bin/SU2/run/merge.py", line 124, in merge_surface assert output_format == 'TECPLOT' , 'can only merge tecplot surfaces' |
June 2, 2013, 09:05 |
What does it mean? I launched tutorial 13 files.I can not find solution file flow.plt
------------------------------ Begin solver ----------------------------- SU2 process was terminated by signal '11' [ec2-user@ip-10-112-119-30 bin]$ |
June 13, 2013, 18:12 |
Sean R. Copeland
Rep Power: 13 |
Hi Yuri,
We're moving away from Paraview outputs in favor of the universal CGNS format. I would avoid Paraview in the future, compile with the CGNS libraries and try again with the CGNS-specified output. This filetype is still readable by Paraview, as well as other open-source visualization tools. It's difficult to say what your error is in your second post, can you provide more information? -Sean |
January 14, 2014, 09:33 |
Rep Power: 13 |
what other software could you recommend?
February 12, 2014, 12:34 |
Thomas D. Economon
Rep Power: 14 |
After updating/improving the output routines, we have reintroduced the Paraview output for the flow solver. Other output formats available for SU2_CFD are Tecplot ascii, Tecplot binary and CGNS. Paraview, Tecplot, and EnSight have all been used by the Dev team, but anything that can accept the formats above as input should work. Cheers, Tom |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
beginner in adaptive mesh refinement | aki_yafuji | OpenFOAM Running, Solving & CFD | 13 | May 7, 2020 03:49 |
[snappyHexMesh] Number of cells in mesh don't match with size of cellLevel | colinB | OpenFOAM Meshing & Mesh Conversion | 14 | December 12, 2018 08:07 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
[snappyHexMesh] snappyHexMesh refinement regions ignored | guitarbren | OpenFOAM Meshing & Mesh Conversion | 2 | April 9, 2013 03:59 |
