error 262144 and unexpected disconnect when run on 2 nodes |
April 9, 2014, 12:13 |
emily
Rep Power: 12 |
Dear developer,
I tried to run Tutorial 2 on 2 nodes (parallel run of course), and the following errors occurred. I desperately need your help! This is what it echoed: raise Exception , message Exception: Path = /home/SU2-master/TestCases/TestCases/euler/oneram6/, Command = mpirun -np 32 -host node01,node02 /usr/local/bin/SU2_CFD config_CFD.cfg SU2 process returned error '1' [3] rtc_invalidate error 262144 Assertion failed in file ../../i_rtc_hook.c at line 207: 0 internal ABORT - process 3 [5] rtc_invalidate error 262144 Assertion failed in file ../../i_rtc_hook.c at line 207: 0 internal ABORT - process 5 [7] rtc_invalidate error 262144 Assertion failed in file ../../i_rtc_hook.c at line 207: 0 internal ABORT - process 7 [9] rtc_invalidate error 262144 Assertion failed in file ../../i_rtc_hook.c at line 207: 0 internal ABORT - process 9 [11] rtc_invalidate error 262144 Assertion failed in file ../../i_rtc_hook.c at line 207: 0 internal ABORT - process 11 [13] rtc_invalidate error 262144 Assertion failed in file ../../i_rtc_hook.c at line 207: 0 internal ABORT - process 13 ...... [25] rtc_invalidate error 262144 Assertion failed in file ../../i_rtc_hook.c at line 207: 0 internal ABORT - process 25 [2:node01] unexpected disconnect completion event from [5:node02] Assertion failed in file ../../dapl_conn_rc.c at line 1054: 0 internal ABORT - process 2 [4:node01] unexpected disconnect completion event from [5:node02] Assertion failed in file ../../dapl_conn_rc.c at line 1054: 0 internal ABORT - process 4 [12:node01] unexpected disconnect completion event from [13:node02] Assertion failed in file ../../dapl_conn_rc.c at line 1054: 0 internal ABORT - process 12 [22:node01] unexpected disconnect completion event from [23:node02] Assertion failed in file ../../dapl_conn_rc.c at line 1054: 0 internal ABORT - process 22 [6:node01] unexpected disconnect completion event from [5:node02] Assertion failed in file ../../dapl_conn_rc.c at line 1054: 0 internal ABORT - process 6 [18:node01] unexpected disconnect completion event from [19:node02] ...... Assertion failed in file ../../dapl_conn_rc.c at line 1054: 0 internal ABORT - process 28 [30:node01] unexpected disconnect completion event from [9:node02] Assertion failed in file ../../dapl_conn_rc.c at line 1054: 0 internal ABORT - process 30 [15:node02] unexpected disconnect completion event from [12:node01] Assertion failed in file ../../dapl_conn_rc.c at line 1054: 0 internal ABORT - process 15 [27:node02] unexpected disconnect completion event from [12:node01] Assertion failed in file ../../dapl_conn_rc.c at line 1054: 0 [29:node02] unexpected disconnect completion event from [12:node01] Assertion failed in file ../../dapl_conn_rc.c at line 1054: 0 internal ABORT - process 29 internal ABORT - process 27 [31:node02] unexpected disconnect completion event from [12:node01] Assertion failed in file ../../dapl_conn_rc.c at line 1054: 0 internal ABORT - process 31 [1:node02] unexpected disconnect completion event from [12:node01] Assertion failed in file ../../dapl_conn_rc.c at line 1054: 0 internal ABORT - process 1 |
April 10, 2014, 18:08 |
Thomas D. Economon
Rep Power: 14 |
Which compiler/MPI are you using to build the code? Does the same issue happen if you try to call SU2_DDC directly without Python, i.e., mpirun -np 32 SU2_DDC your_config.cfg?
Display Modes | |
ANSYS Workbench on "Uncertified" Linux Distros | hsr | CFX | 289 | April 20, 2023 10:23 |
FLUENT installation on UBUNTU 12.04 (LTS) | teymourj | FLUENT | 2 | March 1, 2017 23:24 |
