hdf5.dll
1 Attachment(s)
Dear su2 users,
I installed su2 and then put SU2_CFD and inv_NACA0012.cfg, and mesh_NACA0012_inv.su2 into one file as a test, then run it under cygwin, but it says " error while loading shared libraries: hdf5.dll: cannot open shared object file: No such file or directory". (print screen is attached) What's wrong with it, and how can I solve the problem, looking forward to your help. Thanks in advance. Attachment 31150 |
Are you using the standard installation procedure?
It appears you're mixing platforms. The Windows binaries (Windows installer package) does not require Cygwin, which we don't support. It's a native Windows build. All you need to do is install it and run it per the instructions on our site.
