Problems Parallel install manjaro linux
1 Attachment(s)
hey guys
I'm trying to install SU2 in my manjaro (Arch based) linux. I ran the line parallel_computation.py -f inv_NACA0012.cfg -n 2 and the error in the image appeared for configuring I used: sudo ./configure --prefix=/home/leonardo/SU2_p --with-MPI=/usr/bin CXXFLAGS="-O3" --with-CGNS-lib=/usr/local/lib/ --with-CGNS-include=/usr/local/include/ The serial run is working but the parallel is not P.S I exported the variables. Any tips ? thanks ! |
--with-MPI=ARG Build parallel version with MPI tools, ARG = MPI C++ compiler Hint: Do not forget make clean before rebuild package with new tunings and make install after rebuild |
1 Attachment(s)
Thanks for your answer
I ran sudo ./configure --prefix=/home/leonardo/SU/SU --with-CGNS-lib=/home/leonardo/SU/cgnslib_3.2.1/src/lib --with-CGNS-include=/home/leonardo/SU/cgnslib_3.2.1/src --with-MPI=/usr/bin/mpicxx CXXFLAGS="-O3" but I'm getting the same error What I'm doing is: I downloaded the openmpi 1.8.1 package I unziped it ./configure inside the directory after that I went to root and searched for mpicxx. There's one mpicxx and one mpicxx-vt. the directory for this two files are /usr/bin/ After the ./configure, I edited the bashrc file, pasting the exported variables at the file and saving. after that, sudo make sudo make install sudo clean I tried to run the "parallel_computation.py -f inv_NACA0012.cfg -n 2" and ... the same error. Am I missing something ? P.S I think I have some kind of bug in my system cause when I run the config_gui.py, the gui appears incomplete. |
Sometimes we can't run without a healthy horse. I formatted my system and changed distro. I tried to install SU2 in linux mint debian edition and it worked as butter.Manjaro wasn't stable in my machine I don't Know why.... the line I ran was:
./configure --prefix=/home/leonardo/opt/ss --with-MPI=/usr/local/bin/mpicxx CXXFLAGS="-O3" --with-CGNS-lib=/home/leonardo/opt/cgnslib_3.1.4/src/lib --with-CGNS-include=/home/leonardo/opt/cgnslib_3.1.4/src --with-Metis-lib=/home/leonardo/opt/metis-5.1.0/build/Linux-x86_64/libmetis --with-Metis-include=/home/leonardo/opt/metis-5.1.0/include The only bug is the config_gui.py bug... thank you for the help |
