Problem while Compiling and Installing SU2 3.2 using Cygwin |
July 20, 2014, 16:20 |
Yonatan Afework Tesfahunegn
I am trying to compile SU2 3.2 for parallel run in windows 7 using Cygwin with MPICH. I got the following error: CXXLD ../bin/SU2_CFD.exe ../../externals/metis/libmetis.a(libmetis_a-error.o): In function `PrintBackTrace': /cygdrive/c/Users/yonatant/Downloads/SU2-master/externals/metis/GKlib/error.c:221: undefined reference to `backtrace' /cygdrive/c/Users/yonatant/Downloads/SU2-master/externals/metis/GKlib/error.c:221(.text+0x355): relocation truncated to fit: R_X86_64_PC32 against undefined symbol `backtrace' /cygdrive/c/Users/yonatant/Downloads/SU2-master/externals/metis/GKlib/error.c:222: undefined reference to `backtrace_symbols' /cygdrive/c/Users/yonatant/Downloads/SU2-master/externals/metis/GKlib/error.c:222(.text+0x361): relocation truncated to fit: R_X86_64_PC32 against undefined symbol `backtrace_symbols' collect2: error: ld returned 1 exit status Makefile:611: recipe for target '../bin/SU2_CFD.exe' failed make[1]: *** [../bin/SU2_CFD.exe] Error 1 make[1]: Leaving directory '/cygdrive/c/Users/yonatant/Downloads/SU2-master/SU2_CFD/obj' Makefile:337: recipe for target 'install-recursive' failed make: *** [install-recursive] Error 1 This is my configuration: ./configure --prefix=/home/yonatant/SU2V3 --with-MPI=/home/yonatant/mpich/bin/mpicxx CXXFLAGS="-O3" --with-CGNS-lib=/home/yonatant/cgns/lib --with-CGNS-include=/home/yonatant/cgns/include Any solution for this error? Thanks for the help. |
July 25, 2015, 00:20 |
Muhamad Fakhrusy
Rep Power: 10 |
I want to bump this since I'm getting the same issue with cygwin in Windows 8.1. anyone has an answer for this?
the parallel build keep failing with this kind of error. Code:
../../externals/parmetis/include/parmetis.h:21:0: warning: "__cdecl" redefined #define __cdecl ^ <built-in>: note: this is the location of the previous definition CXX ../src/___bin_SU2_CFD-transport_model.o CXX ../src/___bin_SU2_CFD-variable_adjoint_levelset.o CXX ../src/___bin_SU2_CFD-variable_adjoint_mean.o CXX ../src/___bin_SU2_CFD-variable_adjoint_tne2.o CXX ../src/___bin_SU2_CFD-variable_adjoint_turbulent.o CXX ../src/___bin_SU2_CFD-variable_direct_poisson.o CXX ../src/___bin_SU2_CFD-variable_direct_elasticity.o CXX ../src/___bin_SU2_CFD-variable_direct_heat.o CXX ../src/___bin_SU2_CFD-variable_direct_mean.o CXX ../src/___bin_SU2_CFD-variable_direct_tne2.o CXX ../src/___bin_SU2_CFD-variable_direct_transition.o CXX ../src/___bin_SU2_CFD-variable_direct_turbulent.o CXX ../src/___bin_SU2_CFD-variable_direct_wave.o CXX ../src/___bin_SU2_CFD-variable_linearized_mean.o CXX ../src/___bin_SU2_CFD-variable_linearized_turbulent.o CXX ../src/___bin_SU2_CFD-variable_structure.o CXX ../src/___bin_SU2_CFD-variable_template.o CXXLD ../bin/SU2_CFD.exe ../../externals/metis/libmetis.a(libmetis_a-error.o): In function `PrintBackTrace': /home/fakhrusy/SU2-4.0.0/externals/metis/GKlib/error.c:221: undefined reference to `backtrace' /home/fakhrusy/SU2-4.0.0/externals/metis/GKlib/error.c:221:(.text+0x355): relocation truncated to fit: R_X86_64_PC32 against undefined symbol `backtrace' /home/fakhrusy/SU2-4.0.0/externals/metis/GKlib/error.c:222: undefined reference to `backtrace_symbols' /home/fakhrusy/SU2-4.0.0/externals/metis/GKlib/error.c:222:(.text+0x361): relocation truncated to fit: R_X86_64_PC32 against undefined symbol `backtrace_symbols' collect2: error: ld returned 1 exit status Makefile:673: recipe for target '../bin/SU2_CFD.exe' failed make[1]: *** [../bin/SU2_CFD.exe] Error 1 make[1]: Leaving directory '/home/fakhrusy/SU2-4.0.0/SU2_CFD/obj' Makefile:366: recipe for target 'install-recursive' failed make: *** [install-recursive] Error 1 my configure: Code:
$ ./configure --prefix=/home/fakhrusy/SU2 --enable-mpi --with-cc=/cygdrive/c/cygwin64/bin/mpicc --with-cxx=/cygdrive/c/cygwin64/bin/mpicxx --disable-tecio any help will be appreciated Last edited by v8areu; July 25, 2015 at 10:28. |
July 25, 2015, 10:23 |
Muhamad Fakhrusy
Rep Power: 10 |
I've succeeded building it from source for paralel, finally.
if someone has the same problem with cygwin let me share how I fix the problem. apparently we need to edit 2 files named gk_arch.h and error.c under the directory /externals/metis/GKlib. gk_arch.h: delete or make these lines as a comment: Code:
#ifdef HAVE_EXECINFO_H #include <execinfo.h> #endif delete or make these lines as a comment: Code:
void PrintBackTrace() { #ifdef HAVE_EXECINFO_H void *array[10]; int i, size; char **strings; size = backtrace(array, 10); strings = backtrace_symbols(array, size); printf("Obtained %d stack frames.\n", size); for (i=0; i<size; i++) { printf("%s\n", strings[i]); } free(strings); #endif } now I am capable of running SU2 in parallel with the python script(I've ran it with cygwin terminal, not with the common command prompt on Windows). my configure: Code:
$ ./configure --prefix=/home/fakhrusy/SU2 --enable-mpi --with-cc=/cygdrive/c/cygwin64/bin/mpicc --with-cxx=/cygdrive/c/cygwin64/bin/mpicxx --disable-tecio I am very exited |
Problem compiling Paraview 3.12.0 (ThirdParty-2.1.1) in Fedora 17 (64 bit) | mecbe2002 | OpenFOAM Installation | 2 | October 5, 2012 00:12 |
Problem installing OpenFOAM on Fedora 10 | ptb | OpenFOAM Installation | 8 | March 29, 2011 14:46 |
Pls help last problem to be solved for installing OPENfoam | daydayuper | OpenFOAM Installation | 5 | November 9, 2008 04:59 |
