Home > Forums > Software User Forums > SU2 > SU2 Installation
no cyggmp-3.dll file while configure under cygwin
Old   August 11, 2014, 02:20
Default no cyggmp-3.dll file while configure under cygwin [solved]
Cean
shirazbj is on a distinguished road
I just installed cygwin on win7@32 and copied SU2-master source under c:\cygwin\home\Administrator.
In Cygwin Terminal, I changed to SU2-master folder and run ./configure
It says no such cyggmp-3.dll file.
What should I do now?
Thx
shirazbj is offline   Reply With Quote
Old   August 11, 2014, 08:31
Selmar
Buxxy is on a distinguished road
You probably need to install a few more cygwin packages. Run the installer again, search for libgmp and select (= click once on 'skip') the relevant packages.
I don't remember explicitly installing the gmp libs however, so they might have been a dependency for another package that you'll probably need. Maybe you should start with the gcc c++ compiler if you haven't already installed that.
You'll encounter more packages you need to install, so keep the installer somewhere you can find it.
Buxxy is offline   Reply With Quote
Old   August 11, 2014, 09:25
Cean
Cool. configure is working now.thx.
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 03:30
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 19:43
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
