October 19, 2014, 17:45 |
Drag coefficient gradient: 0 error
Rep Power: 11 |
Hello again,
I tried to optimize NACA65210 for supersonic conditions with C-Grid. I defined all constraints and geometrical parameters clearly. However, when I run continuous_adjoint.py I get the drag coefficient gradient is 0. How can I solve it ? Kind Regards, |
May 26, 2015, 13:30 |
Sravya Nimmagadda
Can you attach your config file for further information?
Display Modes | |
[OpenFOAM] an error in Calculator's equation | immortality | ParaView | 12 | June 29, 2021 01:10 |
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries | NickG | OpenFOAM Installation | 3 | December 30, 2019 01:21 |
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) | Yogini | Fluent UDF and Scheme Programming | 7 | October 3, 2012 08:24 |
checking the system setup and Qt version | vivek070176 | OpenFOAM Installation | 22 | June 1, 2010 13:34 |
How to get the max value of the whole field | waynezw0618 | OpenFOAM Running, Solving & CFD | 4 | June 17, 2008 06:07 |
