Home > Forums > Software User Forums > SU2 > SU2 Shape Design
Error in Tutorial-Optimal Shape Design of a Fixed Wing
Old   January 23, 2013, 01:42
Default Error in Tutorial-Optimal Shape Design of a Fixed Wing
cfdbooks
cfdbooks2008 is on a distinguished road
I have installed the serial source version of SU2 on Ubuntu 12.10(64bit) and tried to run the Tutorial-Optimal Shape Design of a Fixed Wing. I tried the following steps:
$ SU2_MDC inv_ONERAM6.cfg
$ mv mesh_out.su2 mesh_ONERAM6_inv_FFD.su2
change the name of the mesh input file in inv_ONERAM6.cfg
instead of MESH_FILENAME= mesh_ONERAM6_inv.su2
use MESH_FILENAME= mesh_ONERAM6_inv_FFD.su2
$ python shape_optimization.py -f inv_ONERAM6.cfg
Iter Time(s) Res[Rho] Res[RhoE] CLift(Total) CDrag(Total)
100 11.104851 -4.086491 -3.563917 0.285536 0.012296
101 11.098431 -4.098954 -3.568896 0.285536 0.012296
102 11.092136 -4.109356 -3.567447 0.285536 0.012296
------------------------- Exit Success (SU2_CFD) ------------------------
Traceback (most recent call last):
File "shape_optimization.py", line 676, in <module>
acc=1e-12, iprint=2, full_output=1, epsilon=1.0e-10)
File "/usr/lib/python2.7/dist-packages/scipy/optimize/slsqp.py", line 319, in fmin_slsqp
g = append(fprime(x),0.0)
File "/usr/lib/python2.7/dist-packages/scipy/optimize/optimize.py", line 176, in function_wrapper
return function(x, *args)
File "shape_optimization.py", line 319, in df
for key,value in Gradient_Dict.iteritems():
UnboundLocalError: local variable 'Gradient_Dict' referenced before assignment
After running SU2_CFD, the procedure stopped. It seems something wrong in shape_optimization.py. I'm sorry I don't know python. Could anybody help me? Thanks in advance.
cfdbooks2008 is offline   Reply With Quote
Old   January 27, 2013, 19:44
Francisco Palacios
fpalacios is on a distinguished road
Could you please tell us what it the version of the Python, Numpy and SciPy that you are using?
Just in case, could you please also post the config file that you are using and the shape_optimization.py (we have different version of this script), and a file with all the screen output.
Best,
Francisco
fpalacios is offline   Reply With Quote
Old   January 27, 2013, 22:34
cfdbooks
Originally Posted by fpalacios View Post
Best,
Francisco
Dear Francisco,
Thank you for your reply. The version of the Python is 2.7.3, Numpy is 1.6.2 and SciPy is 0.10.1+dfsg1-4. All these packages were installed using "sudo apt-get install" command. The files you need are in the attachment.
Regards!
Old   January 28, 2013, 02:04
Trent Lukaczyk
rktchip is on a distinguished road
Have you set your SU2_HOME and SU2_RUN variables? (an example here)
Thanks!
- Trent
rktchip is offline   Reply With Quote
Old   January 28, 2013, 02:28
cfdbooks
Thanks!
- Trent
Yes. I have set the SU2_HOME and SU2_RUN variables as required.
Old   January 28, 2013, 14:48
Trent Lukaczyk
In you config file it looks like you set RESTART_SOL = YES. This assumes that you have all preconverged solutions for your problem. For shape_optimization.py, this means you need a direct solution file (solution_flow.dat) and adjoint solution files (solution_adj_*.dat) for each objective and constraint function (drag and lift in this case).
So could you try to set RESTART_SOL=NO and make sure it works in this simpler case?
If this still doesn't work please upload the full and verbose command line output one more time and we'll keep sorting it out.
Thanks,
-Trent
Old   January 29, 2013, 00:45
cfdbooks
Thanks,
-Trent
Dear Trent
It still doesn't work. I tried the following steps:
$ python shape_optimization.py -f inv_ONERAM6.cfg -g 1.0
Thanks.
Old   January 29, 2013, 03:24
Trent Lukaczyk
For shape_optimization.py, the option -g takes either 'Adjoint' or 'FinDiff'. I think you might mean -p 1 since you are running it in serial. Try running this command -
python shape_optimization.py -f inv_ONERAM6.cfg -p 1
Best,
-Trent
Old   January 29, 2013, 06:23
cfdbooks
Best,
-Trent
-g GRADIENT SCALE,- g 1.0 means GRADIENT SCALE is 1.0. The tutorial uses the same command. I will try your command later and tell you the result. Thanks.
Old   January 29, 2013, 09:05
cfdbooks
Hi, Trent,
The command( python shape_optimization.py -f inv_ONERAM6.cfg -p 1) worked. Thanks. Whether shoud I chage the item MATH_PROBLE from DIRECT to ADJOINT for this case?
Old   January 29, 2013, 09:10
Trent Lukaczyk
great! i'm not sure where there was a gradient scale setting, but you can always check the python script inputs by asking for option -h
shape_optimization.py will take care of setting the mathproblem for you and it won't matter what it's set at before you start.
regards,
-trent
edit: ah -g was an old option we phased out. the tutorial has changed since to reflect this.
Design of a flapping wing aircraft yahya_azizi FLUENT 0 July 11, 2012 11:26
Question about aerodynamik design (rear wing) Zweeper FLUENT 0 March 24, 2010 06:15
[Other] Question about aerodynamik design (rear wing) Zweeper ANSYS Meshing & Geometry 1 March 23, 2010 08:35
Rigid Wing Design for Micro Air Vehicle A.M.Yang Main CFD Forum 0 March 7, 2002 04:32
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 10:18
