Shape optmization error message with version 2.0.3 |
April 19, 2013, 04:36 |
Anant Diwakar
Rep Power: 13 |
Hello
I downloaded and installed SU2 version 2.0.3 released yesterday. But when I am trying to run a shape optimization case using python script, I am getting an error. It was working fine with SU2 version 2.0 Can someone tell why this error is coming ? The error log file is attached with the post. Thanks Anant |
April 19, 2013, 11:58 |
#2 | |
Tommy Chen
Rep Power: 15 |
I have read the error report that you attached, I have encountered the same error as you did, that's right , absolutely the same error!! I have checked that the history_adjoint.dat file, there is sth wrong in the output file, it seems that the errors come from the inappropriate SU2_SOL output. |
April 19, 2013, 21:09 |
Trent Lukaczyk
Rep Power: 15 |
Hi Anant and Tommy,
The optimization configuration parameters have been updated. Please refer to this post - >> new optimization config options Thanks! - Trent |
April 22, 2013, 06:10 |
Anant Diwakar
Rep Power: 13 |
Hello SU2 Team
There seems to a lot of confusion while running shape optimization cases using SU2 2.0.3 As suggested in the previous post, I modified the configuration file to run shape optimization cases using SU2 2.0.3. But even then errors are coming while running the case. I tried rotating airfoil testcase with SU2 2.0.3 using serial version, but NaN occurred after running for some time. I am attaching the configuration file and the run.log file with this post. Moreover, this case doesn't run with parallel version (log file attached) Please look into this issue. It would be nice if some standard configuration file is provided for shape optimization cases for SU2 version 2.0.3 Thanks Anant |
April 22, 2013, 12:11 |
#5 | |
Trent Lukaczyk
Rep Power: 15 |
thanks! |
April 23, 2013, 05:43 |
Anant Diwakar
Rep Power: 13 |
Hi Trent
I tried the NACA0012 optimization case (non rotating euler flow). This works fine. But when I am trying to run other examples like rotating NACA or RANS RAE2822, I am getting error. I have attached configuration file and run.log file for RANS optimization of RAE2822 airfoil. Can you please have a look and suggest the corrective measure ? Thanks Anant |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
SU2 Version 2.0.3 Released Today (Developer Release) | economon | SU2 News & Announcements | 15 | May 8, 2013 07:03 |
OpenFOAM-1.6 install cookbook | MadsR | OpenFOAM Installation | 372 | November 20, 2010 11:57 |
paraFoam reader for OpenFOAM 1.6 | smart | OpenFOAM Installation | 13 | November 16, 2009 21:41 |
Version 12 speed compared to 11 | maka | OpenFOAM Running, Solving & CFD | 2 | December 21, 2005 05:42 |
