Home > Forums > Software User Forums > SU2 > SU2 Shape Design
NACA 0012 Optimisation
Old   January 28, 2022, 05:57
Exclamation NACA 0012 Optimisation
Abhijith
abhijithmoni is on a distinguished road
I'm optimizing the symmetric NACA 0012. The constraint is based on thickness.
But when I use SU2_GEO. SU2 is evaluating the thickness of the airfoil as 0.
These are my Geometry Evaluation Parameters
GEO_MARKER= ( airfoil )
% Geometrical evaluation mode (FUNCTION, GRADIENT)
GEO_MODE= FUNCTION
Please help me with this.
Thanks
abhijithmoni is offline   Reply With Quote
Old   January 31, 2022, 08:18
Jan Navratil
jannav is on a distinguished road
my guess is, that you must uncomment this:
%GEO_DESCRIPTION= AIRFOIL
Cheers,
Jan
jannav is offline   Reply With Quote
Old   February 9, 2022, 14:29
Abhijith
Hi, thanks for the input. Even if uncomment it. The results are the same.
SU2_GEO fails to evaluate the thickness.
And I can't apply any constraints under "OPT_CONSTRAINT=" for the optimisation.
Old   February 10, 2022, 04:32
Jan Navratil
I tried you input file on my 2D mesh (just airfoil and pressure far field boundaries) and it works. I uncoment thate option what I adviced. But I also commented
%MARKER_SYM = (symmetry)
I guess your case is 2D as well and there is not symmetry plane.
Hope, it will help.
Cheers,
Jan
Old   February 10, 2022, 05:15
Abhijith
@Jan Navratil
Hi, thanks for your reply. I think you are using the full geometry of NACA 0012. My case is symmetric.
So, If I uncomment it:
The following error shows up:
The configuration file doesn't have any definition for marker symmetry
Thanks
Old   February 10, 2022, 06:01
Jan Navratil
OK. Maybe this is the cause of your problem. It might be that SU2_GEO is not prepared to calculate thickness of an airfoil modeled as symmetric case.
Jan
Old   February 10, 2022, 06:09
Abhijith
@Jan Navratil
Yes, you are right. When using SU2_GEO it fails to calculate AIRFOIL_THICKNESS, AIRFOIL_TOC etc.
So I can not constraint the optimisation.
Data for NACA 0012 Muntazir Main CFD Forum 1 March 28, 2023 01:59
Producing Non-Zero Lift Coefficient for NACA 0012 at AOA=0 cagesbuild ANSYS 1 January 14, 2020 17:53
How to import NACA 0012 Profile in Gridgen maplepink Main CFD Forum 17 May 7, 2013 13:01
Problems with flat plate and NACA 0012 Lift/Force Harly FLUENT 0 June 18, 2007 10:02
NACA 0012 simulation results Luis FLUENT 3 February 15, 2006 11:42
